fenderman
Staff member
- Mar 9, 2014
- 36,891
- 21,410
That would require manual intervention which is insane. It would also not stop anyone who has access to the nvr to removing the privacy mask. He needs to secure the NVR and just let it record. Or use a vms that allows disabling a camera by stopping display and/or recording easily. Blue iris can do this no problem. Like every NVR you must secure it or anyone can turn the cams back on.You could create a big privacy zone on your indoor cams which you turn off when you leave the house. Effectively, they are blind then. But they do draw electricity still.
