That is the only thing I haven't tried and is about the only thing left to try.I wonder if it might stop while using a 12v 1.2 or 2.0 amp wall wart?
If that works, then it probably means the cam has a problem, not the network.I wonder if it might stop while using a 12v 1.2 or 2.0 amp wall wart?
It's had no issues while plugged into a 12v 2a power supply all day. So there must be something fucky with the camera.If that works, then it probably means the cam has a problem, not the network.
Other than having the camera serviced/replaced, this would be an option. However the location isn't horrible to run wire to and I do already have a power supply close by feeding some IR illuminators I could maybe pull power off of.
Yea, I would be running a dedicated line to the camera if I went this route. It's a 5a power supply with 40w of IRs on it right now. I should be fine adding this, but would possibly go a little bigger if I added it.Just watch the load on the power supply and what the voltage drop might be on the cable supplying the IRs and camera.
You need to setup a zone crossing also post your annalist details like the below screenshotI am finally getting back to working on my LPRs and can't figure out what the issue is with not getting consistent captures of the car/plate within the frame. Or why it takes shots of the front of cars with no license plate.
This is what I am wanting to happen, let me know if it is possible:
- BI detects motion in the FOV and sends the image to CP.AI.
- CP.AI verifies there is a plate in the frame and posts the image as an alert.
- The license plate information is burnt onto the image, file name, etc.
Below is what I am getting, and most of the blank captures were triggered by a plate but this is what UI3 is displaying.
These are my settings and I have ALPR turned on in Global Settings.
How did you open the Analyze window, you need to hold down the CTRL key and double left click on the alert and the window will open up with the details.It appears I did not have the LP module installed in CP.
My AI Analyze list is completely blank?
I am getting this in my Alerts.
And this in my Clips.
Right click on the alert and click on Open containing folderI have them set up in separate groups, but I do not get a still capture of the license plate. I only get a 3 second video in Alerts or an absolutely non-useful still capture in All Clips.
Where do I find this image?
