Looking for guidance to replace a Foscam FI9831W camera - BlueIris, 5V, WiFi, possibly Ethernet/PoE down the road
nikleb
Jan 4, 2015
93
4
I kept using a FOSCAM FI9831W to monitor entrance hallway as part of my BlueIris setup. Other than that I ma using HikVision outdoor compact cameras. The Foscam seemed to be sufficient but died...
FOSCAM FI9831W spec
  • Resolution: 1.3 Megapixels (1280 x 960)
  • Lens & View: 2.8 mm lens, 70°–80° viewing angle
  • Wi-Fi: Supports IEEE 802.11b/g/n (2.4 GHz band)
  • Wired Ethernet: 10/100 Mbps RJ45 port
  • Night Vision: 11 infrared LEDs, up to 26 feet (8 meters)
I am looking for a replacement:
  • Don't really need PTZ
  • Looking for similar view angel (not less)
  • Ideally 5VDC so I can keep using a backup battery setup
  • WiFi for now - possible Ethernet/PoE down the road
  • BlueIris supported - so any device motion detection is not a must
  • Similar or better night vision
  • Ideally similar wall mounting style (see pic) - preferably not sticking out more
What should I look at?
  1. Amcrest IP2M-841W
  2. Reolink?
  3. Foscam R4M (might even work with my wall mount?)
  4. Unifi G5 Turret Ultra
