aristobrat
- Dec 5, 2016
- 2,979
- 3,180
The 23.63W came from my PoE switch -- it shows the current load (via a mgmt interface).
My APC UPS also shows the total load, but since I have a bunch of other devices plugged into it (in addition to the PoE switch), I would have to unplug everything except the PoE switch to see the load.
I'd expect your PoE power consumption to be similar as well (keeping in mind that it goes up a bit at night when the IR lights kick on).
I don't have the 60lb APC ... I have the 20-something lb unit that you first linked to. It looks similar to the CyberPower one you linked to. The 60lb one you linked to later was different than the first one you linked to.
As for what else I have plugged into mine, it's mostly network stuff. There's another switch (non-PoE), Internet modem, router, a little Synology NAS, and a VPN-appliance that my housemate uses to connect back to his work (he works from home). Oh, and two WiFi access points.
I actually have two of these UPSs. One is for the networking gear above, and a second one is for my Blue Iris PC (which is my NVR). This pic is from when I was building everything out, so please excuse the mess. The UPS on the left shows the load of all of the networking stuff, and the UPS on the right shows the load of the BI PC.
With only 4 ethernet ports - what would you hope to achieve?Can I set up a VLAN? It looks like I might be able to, but I am not sure, and am not sure how.
A VLAN is a mechanism for logical grouping of network ports and provision for controlling whether traffic can flow between them.
Generally there would be quite a few network ports and associated groupings involved, such as a set of cameras and an NVR, WiFi access points, PCs and laptops and gaming devices, etc.
That is true.I thought that since the NVR would have PoE switches built in, I wouldn't need ports on the router.
One, either for:My NVR will have 16 PoE switches built in. I'd be getting 8 cameras, connected to the NVR. If I wanted to set up a VPN, how many ports would I need on the router for the NVR and cameras?
I would go for the 2017. But even that would be overkill..Bump, thoughts on which year TV I should buy, the 2017 or the 2018?
Any tv would be fine. You only need hdmi.
If I were in your situation, that's exactly how I would do it.So right now I'm thinking I should connect the NVR, router, and modem. I don't think the Ooma Telo and landline phone consume much power, so probably those too.
Then, for the Tivo, see what the total is for the other devices without it. If it's low enough, then add it. Otherwise, don't, or wait until I get a 2nd APC.
Each situation is different. For me, keeping the network up and running (one of the folks in the house works from home) is the #1 priority, so I have a UPS for just the essential networking stuff (modem, router, separate WiFi access points, etc). I have a second UPS for the computer running Blue Iris and the PoE network switch, which powers the cameras. My TiVo is in a different room where I have it plugged into a third (and smaller 650) UPS.
I do have VPN set up. Good job on getting yours setup, that is the safest way to connect back into your network.
For that PSU calculator, I think that was probably "maximum power consumption" and that your regular day-to-day usage will be lower.
I use this UPS for my TiVo: 650VA APC UPS If I were buying now, I'd consider getting the newer, less-expensive 600VA model. I haven't gone through the reviews of that model though...
I need to update those pictures you looked at as I've reallocated the load. The picture with the UPS showing 48W was just my PC... I hadn't moved the PoE network switch over to that UPS yet. So the "networking" UPS should go down about 20-25W, and the "computer" UPS should go up by that amount.
Yes and no. I've accessed recordings remotely using the iOS TiVo app on both my iPhone/iPad (I do this a lot while waiting in the exam room for my vet, ... they're great, just really slow), but I've never done it remotely with a PC. It looks like the "kmttg" Java app might be a more automated way of doing what's listed in your first link above. If you haven't found it already, check out the TiVo Community forum over at TiVoCommunity Forum. Lots of good info, just takes some searching to find it sometimes.Since you also have a Tivo, have you tried to access your recordings when on a remote network, perhaps by connecting to the VPN first?
