tangent
- May 12, 2016
- 4,641
- 3,996
Residential lightning protection systems are generally a bit less extreme than nayr's post above. But putting those spikes all over your roof wired together and installing a ground ring still isn't cheap.
If you want to test the cables (for lightning damage), I don't think there's a tool quite optimized for the purpose. You could use a megaohm resistance meter, but that would get extremely tedious as you'd have to preform dozens of tests per cable (sorry too tired to do the math). Cat-5e/6 cable is generally only rated to 250V, you have to test at a lower voltage than that. megaohm resistance meters are used to test the integrity of wiring insulation and do so using fairly high voltage.
My Aunt's house had a direct strike that put a hole in the roof, fried everything, and fused all her alarm contacts and damaged the alarm wiring.
