my UAC has been disabled for years.. Been running BI4 from the day it was released without an issueShould be able to disable UAC and it will run? If you don't want to update.
Yes! i noticed thawte when i was poking around.. i just got off work and havent had much time to look into it.Here's what I see in certmgr.msc. Do you have a thawte root certificate that's not trusted as well?
To be fair, the title of this thread is not very "searchable"... the one I started at least mentioned uac error... and the body of original post in this thread had no text.
I mean, now someone searching should find key words in the body of the replies...
When I said "another forum" I meant not ipcamtalk...
I wonder what repercussions are had by disabling UAC if any. I assume that is part of the overall security features of Windows OS.Making this change in the registry got me going again:
How to Fix
If your PC won't let you open an app, and you aren't using a PC owned by someone else, try these tips to unlock it.www.makeuseof.com
What solutions have they come up with on the other thread? Can you share the link?To be fair, the title of this thread is not very "searchable"... the one I started at least mentioned uac error... and the body of original post in this thread had no text.
