fenderman
Staff member
- Mar 9, 2014
- 36,891
- 21,408
There is absolutely no need to do this when there are several other perfectly good workarounds already posted.Does someone want to be the tester LOL.
Rumor is you can install the latest BI on a different computer (obviously it is in eval mode) and then copy that BlueIrisAdmin.exe file from that installation and replace the existing one in C:\Program Files\Blue Iris 5 on your BI server and everything works fine like nothing happened and lets you stay on whatever V5 update version you are on.
I am guessing that the blueirisadmin.exe file must simply be a pointer to the actual install files?
