Issue With Outdoor Cams
wee-haggis
Sep 20, 2018
14
1
canada
I have 5 x Zosi C298 cameras.
2 Indoor and 3 Outdoor.
Whenever there is a power outage and the power is restored , my 3 outdoor cams do not automatically reset.
The 2 Indoor ones do .
I have to reinstall the 3 outdoor cams from scratch every time the power goes off and back on.
All 5 cameras are identical and they all connect via wifi.
Does the Zosi c298 user interface have a for setting a "static" IP vs. a "DHCP" in it's menu?
Routers will sometimes assign existing devices new DHCP Ip addresses after everything loses power.
If you can set a static IP, it should be able to be seen again upon restoration of power.
Not familiar with newer Zosi cams. I had a couple 2 megapixel ones 4-5 years ago.
