bigredfish
If all of your cameras are using the same password, set that same password as your admin account on the new NVR.
Reboot - login to verify new admin password works
Then after logging into it to verify the new password (same as your cameras) works, simply plug the cameras into the NVR*
Reboot NVR
*Do one at a time, dont fuck with any other buttons, wait, smoke a cigarette or go to lunch, when you come back and login or refresh they will all be connected
With the pass on the cameras and a PoE NVR the same, PoE ports work like magic and make the connection.
If you want to manually "factory default" all of your cameras and NVR before you start the above process, knock yourself out
