Thanks for sharing your experience with thermal. Your comment led me down a rabbit hole on thermal sensors, and one thing I noticed was that the TPC124X-AI-S2 (maybe the same as TPC-DF1241-S2?), seems to have different advertised sensitivity vs the DH-TPC-DF1241-D3F4. Specifically the former is rated with a Noise Equivalent Temperature DifferenceI of 40mK while the latter is rated at 50mK. I wonder if that's meaningful, or reflective of a more broad difference. Coming back to your recommendation, I'm not sure if PTZ would be good in my specific case. I'm thinking the alternative would be adding IR emitters?
Thank you for the guidance! Because there's a porch my plan was actually to use the variofocals near the rear entries and windows for identify. Then, use additional cameras for overview to see further out. That's where I thought that maybe the Color4Ks could fit that overview role. But once I saw the image at 16ms, I knew it wasn't going to work out.
I've read (and reread!) your prior review of the TPC124X-AI-S2 and had a couple questions. Wisdom here seems to be that you can't really trust DORI distances on spec sheets. That makes sense. But you've referenced being able to trigger on a person at over 400 feet with the 3.5mm version while the spec sheet says it can do something like 479 feet. Does that mean that the thermal performance is close to what's on paper? Related- the thermal perimeter distance for a human is specified as a completely different number - 80 feet. That appears to be very different vs all of your testing, but I'm not sure what the difference is. What am I missing?
Yeah, in my testing, the Detection and Observe numbers provided for thermal cams seems to be pretty accurate. I think because the image looks the same regardless of the light conditions.
Now the Recognize and Identify for thermal, no way LOL. Here is someone less than 10 feet from the camera or well within the IDENTIFY distance for the thermal LOL:
The perimeter distance number you reference of 80 feet is under the "General" number, so I am assuming that means they distance they have high confidence in that it would trigger for anyone within that distance.
But you do have to manage your expectations - when I referenced the 400 feet - I could tell that was a person and not a deer as an example, but would never be able to provide any additional details like male or female, etc. but I was able to see where the person was going and hiding behind bushes that I simply could not see at that distance with a visible camera with a shutter speed set to minimize blur.
