alastairstevenson
Staff member
I usually need to use a magnifying glass - and some strong lighting.The numbers are verry smal,
Possible candidate - 25L12......
That's a 128Mbit SPI flash memory chip.25L12835F
Did you decode the firmware before trying it?Looking at the firmware you used that was linked to earlier in the thread, the jdvr-recover-sw-nd6004-h1-2.0-128M.bin seems to be a simple XOR-encoded monolithic flash dump of a 16MB flash chip. Presumably you decoded it before you used it? I don't think I saw that mentioned.
On the probably big assumption that the recovery file as published is obscured by a simple XOR encoding, attached is a possibly decoded file.No, I did not decode the firmware.
I didn't do the decoding correctly - the attached version looks OK, apologies.But on examining the contents - I suspect that there may be some further decoding needed, I don't see the expected signatures of a raw firmware dump.
Simply by inspection using a hex editor.Just out of interest, may i ask you how you did it? Can you refer to a howto maybe.
OK, so you are able to write the dump file to the flash chip and read it back correctly. That's a pretty good state to get to.The programmer does not give an error message verify is ok.
