Is Reolink RLC-840WA supported in BI? Also, is there another outdoor dome WiFi cam I should look at?
nikleb
Jan 4, 2015
102
5
I need to replace an old Hikvision WiFi 2.8mm compact dome camera. Unfortunately, at this point I can't really run PoE to location.
So, I looked for similar WiFi cams.
Using Copilot I found Reolink RLC-840WA. Is this supported by BI? Other cams I should look at? Don't really need PTZ, but a bit more view angle woudl be great.
In short, "yes" but I would not recommend any brand of 8MP camera with a tiny 1/2.49" sensor as it will have terrible low light performance if there's any motion.
Additionally, Reolink cameras (except their video doorbell) have a terrible reputation with BI.
