Electrical engineer here. You can run copper..... the grounding won't be an issue.
One more time . . .
Please cite anywhere in the NEC / CEC / Any industry standard that affirms the above?!?!
Lightning. That bright light in the sky that occasionally hits the ground. Creates magnetic fields....
Nothing wrong with optically coupling either- but not required...
How about you explain to me and everyone else on this forum what should be done if copper wire is to be run and connected to two different building structures with a separate grounding system?!?! For me anyway, one of the documents I linked to in post #17 explained this clearly:How about you explain to me and everyone else on this forum what should be done if copper wire is to be run and connected to two different building structures with a separate grounding system?!?!
"Environment B, the stricter isolation requirement, is for PSEs attached to Ethernet cables that cross an ac power distribution boundary. That is, electrical equipment near at least one cable connected to the PSE is wired to a different earth ground than the PSE or equipment near another cable. To prevent hazardous shocks due to different ground potentials at the end of each cable, Environment B PSEs have electrical isolation between all of their PoE ports; each pin in every RJ-45 jack must be electrically isolated from the PSE's chassis and the pins in all the other RJ-45 jacks on the PSE."
This document is specifically about POE switches, but I'll point out that all non-poe switches have the same or stricter isolation requirements. Those are in the "Review of IEEE 802.3 Isolation Requirements" section of the other linked document. Note that equipment damage isn't even mentioned as an issue. It's about the personnel risk if multiple PSEs add their floating PSE voltages to a point where it's a shock hazard.
I am very familiar with Lightning and best practices / industry standards to mitigate the same. Since you went out of your way to declare you're an Electrical Engineer.
Why would you promote and affirm an installation method that flies in the face of all known standards and best practices???How about you explain to me and everyone else on this forum what should be done if copper wire is to be run and connected to two different building structures with a separate grounding system?!?!
Ethernet is magnetically coupled. There is no ground wire in it. Thus, there are no grounding issues.
Often, you use shielded wire where you ground the jacket... You need to look out for ground loops in that case...
Someone posted this a while back...
How To Fix a Ground Loop When Using an Ethernet Cable
Knowing how to fix a ground loop is very important, but preventing it from happening in the first place will save you future headaches. Learn more at trueCABLE.www.truecable.com
There are literally MILLIONS of buildings connected by copper ethernet with different power sources and grounds. The whole magnetics portion of the standard is designed precisely for this reason.
Obviously follow whatever codes are in your local area.
And I personally am a fan of running fiber in this case as well, but it isn't required.
As I suspected, please just stop offering bad advise . . .![]()
It is perfectly sound advice. It is also sound to use optics... both decouple the buildings.
The back peddling and mental gymnastic one has to do to accept what you have stated here is simply incredible. As stated very plainly show me where in the NEC / CEC / Any standard that affirms what you said there will be no grounding issues much less says it's OK to do so???
Show me . . .
I also replied to another forum member as to what should be The Plan before one endeavors to start such a project???
I'll wait with abated breath as to the answers to the questions I posed up above from you.
Because, after all You're an Electrical Engineer!![]()
Yes. ASIC designer. I posted the grounding concerns if one chosen to use shielded wire. I recommend ubiquiti surge protectors at each end.
I don’t have time to look for the Canadian code. Don’t care if you take my advice. The cable modem systems connect to all houses and don’t use optics either. This is basic stuff.
you an electrician? They tend to go by the code and not understand the fundamentals.
As you stated it is Basic Stuff which is clearly out of your depth of field.
It's so basic you can't even answer that simple question posed by another forum member?!?!For communications circuits, NEC article 800 says that surge protectors may or may not be required based on lightning exposure and earth resistivity. It also gives guidelines for terminating metallic sheaths for runs between buildings. Where does it require a metallic sheath? I can't find it. If no metallic sheath, no grounding issues. just as wpimamn has been trying to say. The isolation requirements of IEEE 802.3 and IEC 60950-1, if you understand them, say there are no issues with respect to the different grounding systems.How do I connect two buildings using separate different grounding systems - safely, correctly, and to accepted industry standards.
Show us where they say there WILL be grounding issues. Or do you want to just continue throwing rocks?show me where in the NEC / CEC / Any standard that affirms what you said there will be no grounding issues much less says it's OK to do so???
Lightning mitigation is never a bad idea. Neither is using optical.
Ethernet wires between building never “touch” so the buildings are isolated. We routinely run Ethernet from hangers to planes and they have a ground and a floating ground. All is good. If you are designing an Ethernet switch-
You ground your end and magnetically couple to the line.
Ethernet is designed so you don’t have to worry about grounding- at least temporarily. Lightning mitigation is trickier for long term connections.
This is your professional Engineering answer / reply to a valid question???As you stated it is Basic Stuff which is clearly out of your depth of field.
At the end of the day every other reply you offered only happened AFTER you were challenged to provide substantiating facts.
You continue to ignore all the prep and considerations as to grounding . . .
Lots of context here. The very first post says he wants to have the POE switch in the son's house, Post 9 explains that he wants to have 7 cameras, and the actual wire distance between the houses is 130 feet. The irony is that the grounding and surge protection requirements in NEC are the same, regardless of which house the cameras are powered from. If anybody reads it differently I'd like to see it explained.Run burial Cat6 to son's house to power the cams via a POE switch in your house.
Not strictly correct.Grounding is not an issue at all because Ethernet over cat5/cat6 is magnetically coupled.
