lewic
Pulling my weight
CCA has been used for lots of new build houses so having CCA is nothing new. Just note that the ampacity of a CCA cable is not the same as using a copper cable. Usually would need to spec a little thicker to make up for it. The question is the quality of the CCA cable. If we are talking about the conductors themselves, I have seen CCA cables that are very brittle. Seems a slight bend in the cable would snap a conductor. Other times seems the aluminum has another metal mixed in or something letting it be more malleable. We also need to look at the type of jacket for the cable itself. Basic CM? CMR? CMX? CMP? This would let you know how the manufacturer intended for you to use this cable. The million dollar question is whether it is okay to use. Yes you can use if if you already have it. It will work. Don't try to push too much POE power through it. Signal transmission probably not as great as there is more resistance in the wiring so I wouldn't use it for longer runs. If you spec-ed out the correct jacket on it then it should be more or less fine to use. Just note that if there is a choice, always go for OFC (full copper).
