Is CCA cable really that bad? Should I rip it out?
CCA has been used for lots of new build houses so having CCA is nothing new. Just note that the ampacity of a CCA cable is not the same as using a copper cable. Usually would need to spec a little thicker to make up for it. The question is the quality of the CCA cable. If we are talking about the conductors themselves, I have seen CCA cables that are very brittle. Seems a slight bend in the cable would snap a conductor. Other times seems the aluminum has another metal mixed in or something letting it be more malleable. We also need to look at the type of jacket for the cable itself. Basic CM? CMR? CMX? CMP? This would let you know how the manufacturer intended for you to use this cable. The million dollar question is whether it is okay to use. Yes you can use if if you already have it. It will work. Don't try to push too much POE power through it. Signal transmission probably not as great as there is more resistance in the wiring so I wouldn't use it for longer runs. If you spec-ed out the correct jacket on it then it should be more or less fine to use. Just note that if there is a choice, always go for OFC (full copper).
So you would consider that sage advice? :rolleyes:
If the cable is already run then I would say use it with caution. I would de-rate your expectations. Not everyone has the budget to rerun cabling. If this cabling was run for a new build then most likely was stapled down which makes it worse. For a low power camera which is running 10 watts. Sure. Just use it. Something that is high POE? I would be more iffy on that. If it is just for networking but no POE power.... Sure... why not? It is all about the cost involved with changing it all out so wire, terminations, labor and how much having to keep and use this wiring bothers you. Only you can decide that.
"If this cabling was run for a new build then most likely was stapled down which makes it worse. "
OMG .. CCA is super brittle compared to pure copper .. gonna be broken if stapled
Yes. CCA IS super brittle. When I had my house built, I wanted it prewired and was surprised to find out that the standard charge... the cables included was for running the lines using CCA. OFC wiring was an expensive upgrade. I would say most people probably didn't ask what kind of wiring is being used. I personally wouldn't use CCA but I know a lot of CCTV installers where that was all they use for their installs. They would only pick up OFC if the customer requests. And yes for my prewire they did staple it all in. They said it was required by code. Only wires that wouldn't be stapled in was if I requested them to run a smurf tube.
If UL won't certify it, that should tell us something. The part that concerns me is that, even if the cable is/was not the source of a fire, the jacket can help spread the fire from ANOTHER source in the walls or between the floors if it does not meet flame test criteria. :wtf:
Excerpt:
"Less expensive than using solid copper, cables made with CCA conductors are simply not worth the risk. Not only are they non-standards compliant, but they often do not have a valid UL safety listing per the National Electric Code (NEC).
What about that UL mark on the box? If the cable is made with CCA and claims standards compliance, it could be counterfeit cable, and that means the UL mark is likely unauthorized. UL listed cables got their safety listing because they passed strict flame spread testing to reduce the spread of fire. If the UL listing is fake, there's a chance the safety is too."
I know electrical wire they do have some CCA that is UL certified. The brand that comes to mind is CopperWeld. So UL certification for CCA is possible. Do they have it for network cable? No idea. Please don't think that I am endorsing the use of CCA cabling. But if someone already has it in their home then they would need to consider what they are using the cable for... The amount of wattage that they are trying to use for POE power... Look at the jacket of the cable to see what it is rated for, etc. It is just silly to outright say no don't use it and pay a low voltage guy at least $100 for a basic drop when you are running a low power camera. It all depends on use case scenario and the person's budget.
Yep, revived from the 70's to allow lighter and cheaper costs of wiring up homes mainly. It's ALWAYS about money
If you've ever discovered the errors made in conductor size and circuit breaker choices made by many self-proclaimed "electricians" when wiring up homes using the conventional materials of the last 50 years you'd understand the likely incorrect choices that will be made using CCA electrical wiring on these new, future jobs.....a LOT of new and different requirements.
I'm not saying it cannot be used safely or done right...I AM saying you lessen the chance of that happening when you keep changing the materials and the requirements mandated by those materials.
CCA cable is hard to work with. The signal travels on the skin of the cable. Think wave guides and such. Never damage the outside of the CCA cable. The higher the frequency the more it propagates along the outer skin of the cable. That's probably why CCA can test as well as solid copper....as long as the outer copper skin is perfectly undamaged.
Not talking about CCA cable, but I have purchased some double jacketed, gel filled direct burial cable that cost a lot, but is great to terminate due to the 2nd layer jacket inside makes it easy to attach an RJ45 connector.
I love the double jacketed direct burial cable.
CCA SUX to work with and is not worth any money you save. Always purchase solid copper. I'm not that worried about a fire hazard with CCA as I am the signal degradation. JMHO.
When I installed telemetry systems alongside GE Field Engineers they only wanted Cat5e and Cat6 copper. Obviously they have a deep budget. They wanted 568B terminations. Unless you were at some Freaking OLD school building in Waukesha county where they set the whole original backbones up as 568A. They wanted the cables Certified with test results.
So I had good luck doing things their way, and I pretty much followed that on my other installs later on.
I saw some CCA at a garage sale and passed on it. I have found partial reels of Cat5e copper on ebay at reasonable prices.
I probably should be installing Cat6 at this point, since I have 1 Gig Fiber now.
@IAmATeaf For sure. We are not processing 8Gb raw images from the Vera C. Rubin telescope out in the Atacama Desert over fiber to the SLAC National Accelerator Laboratory in California.
Reactions: TonyR
Reactions: Flintstone61
The SLAC is an interesting view when driving I-280 in Palo Alto.....:headbang:
yeah? checking for more info. Wow. they get a 100-gigabit link to stare at the sky, meanwhile I'm working a second job for my Medicare prescriptions and copays. :)
Data Centers: Raw images are first stored in Chile, then transmitted instantly over dedicated 100-gigabit internet connections to the primary archive center at the U.S. Data Facility at SLAC National Accelerator Laboratory in California, as well as partner data centers in France and the UK. [1, 2, 3]
