S Stephen Drake Getting the hang of it Jun 12, 2017 116 5 Jun 25, 2017 #21 Thanks so much for all of the input! I'll look at Blue Iris and see if it will work for me
fenderman Staff member Mar 9, 2014 36,891 21,417 Jun 25, 2017 #22 Stephen Drake said: Thanks so much for all of the input! I'll look at Blue Iris and see if it will work for me Click to expand... MILESTONE xprotect is free for up to 8 cameras..another option..
B bearclaw Young grasshopper Feb 18, 2015 38 5 Jun 25, 2017 #23 Sorry for the delay, the dimensions for the foam ring you need are 14mm inside diameter x 24mm Outside Diameter x 10mm thick. As I said it has a notch cutout for the Day night sensor which is approx 5mm diameter. Hope this helps.
S Stephen Drake Getting the hang of it Jun 12, 2017 116 5 Jun 25, 2017 #24 No worries and I appreciate it! Worked perfectly! Below is before and after. Attachments IMG_0532.PNG 1.7 MB · Views: 17 IMG_0538.PNG 2.6 MB · Views: 18
