- Jun 12, 2017
- 116
- 5
Return itThanks! It's obvious it is the lack of a foam ring. I don't seem to have one. I bought the camera used from B&H photo. Any ideas where to get one?
tell us the model and deal...it might not be as good as you think..That's really awesome of you. If you have time I would really appreciate it. I bought it used from B&H photo so I got a good desk on it. Hate to send it back.
Don't use bullets you'll have issues with spiders... 134 is way too much for that camera you can get it new for about the same....I am up for suggestion about a better set-up. I use the turret cameras on the patio and in the garage. They seem to illuminate at night better. Thinking about two bullets on the outside but I'm really liking the look of the domes much more. The mini ptz looks interesting but I think it will be difficult outside for me. My roof line has a deep slope.
there are a million threads discussing how and where to purchase cameras...Really? I mostly saw it for $200. Where do you buy from?
THere are sellers that are known here that sell international versions...they are reliable..you can update firmware on arrival to confirm...Oh okay thanks. Sorry, I'm new to all of this. This is the first time I've ever been in an attic. I have largely been scared off of buying from AliExpress due to firmware issues.
if you want to use the cameras smart features like line crossing then yes stick with one brand...note that you can find the hikvision camera for less as well, new..Thanks so much! Last question, I swear. Now that I have several Hikvision cameras, would it be crazy to throw a Dahua in the mix? Should I have all of one brand? I do plan on adding an NVR but not sure if the dahua will connect.
