I am talking about moving the field of view such that the pole isn't even in the field of view (granted that might then not be the field of view you want as your front yard probably isn't in the picture then.  If the clip you are referencing is from Post 1 above, that hasn't locked on to the car at that point.
I have one camera that will show no SD card as well.  Pull the power to the PTZ for a few minutes and then plug back in.  Then the card should show and then do a reformat.
You could also limit the movement of the PTZ to the left to stop that initial pan.  Unfortunately when you do that, you cannot manually go left past that point.
