Weird that you are still having problems especially if you are using direct-to-disc. These cams are solid.
Take the cam and connect to POE switch using a very short cable temporarily. See if that fixes your problem.
If not, try another POE switch.
These suggestions are to rule out issue due to bad cable or power supply.
