Stuck on this page...
The automatic dimming of the IR emitters when a person moves closer to the camera to prevent “washout”. It doesn’t work currently and requires you to manually reduce the IR output and/or gain to prevent the washout.What is smartIR and how should it be functioning exactly ?
Opening live view and focusing/zooming from there works for me in chrome.The "Focus and Zoom" tab of my IPC-HFW5442E-Z4E no longer shows video when using this firmware. If you want to focus now you have to open the camera up in another program (e.g. Blue Iris) and focus from there. Andy have you reported this to Dahua?
I would set back to factory system defaults, and set it up from scratch, not by importing a settings file.After updating my cameras with this new firmware I regularly have cameras which restart on their own once a day although I have unchecked "automatic reboot" is this a bug?
I have done a hard reset but i have uploaded the saved config after this ...
BICK
Release notes do mention a known bug where it reboots after IVS.After updating my cameras with this new firmware I regularly have cameras which restart on their own once a day although I have unchecked "automatic reboot" is this a bug?
With this new version ?Release notes do mention a known bug where it reboots after IVS.
I've lost count to how many times I've rebooted the cameras' NVR and factory reset...@random101, I have seen that when I updated the firmware of a camera recently. I always reboot the camera before I do a firmware upgrade - but on this one occasion, this camera was stuck on that screen you showed, even though I had re-booted prior. After waiting for some time, I refreshed the browser page. The camera's login screen re-appeared. I then logged in and saw that the firmware did not stick. I rebooted the camera again. Then uploaded the firmware file again and it worked. I did my upgrades from the camera's GUI as they are connected to an external PoE switch as opposed to the NVR PoE.
Via the NVR i can log into the camera, but the firmware upload and install doesn't start.You can't connect directly to the camera IP address and update from within its own GUI? What prevents you from doing that?
Same here, i had to do it via seperate POE injector en connect it to my routerWhat is smartIR and how should it be functioning exactly ?
