The latest smd3.0 V2 with smart IR firmware is ready, and can do testing now, any one is interested, just contact me, thanks!
Smart Motion so far appears to be doing well.The latest smd3.0 V2 with smart IR firmware is ready, and can do testing now, any one is interested, just contact me, thanks!
I had the same thing happening, to stop the triggers I turned down the Sensitivity and turned up the the Threshold. Now I will see if I still get the human triggers.Okay well that was a bust, SMD did pretty well during the daylight hours, as soon as it got dark it started triggering on every little bug that flew by the camera even 10-15 ft away.
I'll now turn off the smart motion detection, and use IVs intrusion zone see how that works.
This is after you made the motion setting adjustments?One of my camera's that I am running in color 24x7 SMD was able spot a human at about 100 feet away
Ok thx Andy. I just installed FW u recommended and smart ir doesnt work i have to set manually so it doesnt white out face up close. SMDZ human/ vehicle seems to be working as well as IVS. I will wait till wildcat does his tests!will post on the forum soon, can contact me for the beta version.
which version not work? The firmware on 1st page can work well. Most guys here use that one, the new one mainly for SMD 3.0 UPDATE.Ok thx Andy. I just installed FW u recommended and smart ir doesnt work i have to set manually so it doesnt white out face up close. SMDZ human/ vehicle seems to be working as well as IVS. I will wait till wildcat does his tests!
i did not default after updating. Do i ho back on web gui or can i default from nvr? Thx.Make a default after you finish the updating.
default from NVR also can be OK.2.820.150G001.0.R,2021-05-2
