IPC-T2431T blurry/pixelated image during day
If that cam has it, try H264B or H264H instead.
Currently, i'm using H264, will try H264B (it doesn't have H264H).
Disable the tripwires and see if that helps, sometimes more than two IVS rules overwhelms the cameras cpu.
do I need to restart after disabling IVS?
Do you see this same problem in the cameras direct live view or only in Blue Iris?
I use a Dahua NVR, yes I see it both on recorded videos and when using live stream (main stream).
As an aside, turn off the Audio Noise filter, and the audio will improve.
Will it make it too sensitive, to wind noises?
I'm monitoring audio mutation event (this way I detect if a truck or heavy machinery is moving in the street or any other weird loud noises)
Are you sure you are not looking at the substream? If your network cannot keep up, the gui will automatically switch it to substream.
I'm using this to watch the main stream:
Code:
vlc --rtsp-tcp 'rtsp:/myuser:[email protected]:554/cam/realmonitor?channel=4&subtype=0'
I'm using a network cable (I have a few network hops, NVR, managed switch, router) , when i'm watching both IPCs (I have 2 IPCs) main stream the network utilization is 16MBps, so I don't think the slowness i've experienced is related to the network.
I can try again with the Iframe, maybe I didn't configure it properly, or maybe a IPC restart is required?.
What Iframe/framerate value to use on the mainstream and on the substream?
Can you connect to your network a few hops closer to the camera and monitor the feed to see if it is any better?
I can but will take me some time, the NVR is on different floor than my PC.
Guessing this is not related to the network hops, since the IPC is connected with one cable directly to the NVR which records the main stream to disk.
Maybe you are approaching the capacity of the NVR? If you unplug all the cameras but this one, does it improve?
How about logging directly into the camera's web interface and doing a live view?
Edit: sorry, late to the party, you may be viewing it this way to begin with.
You keep adding more to the mystery. Watching on VLC, now an NVR is in the mix.
It is becoming clear it isn't a camera issue but rather an issue within your network or peripherals.
Not all NVRs are created equal and a budget NVR can be overloaded easily.
What NVR model and brand?
Time for a network topology map showing all devices and and demands on the system.
Try the camera with a power supply connected directly to a computer and what does live view in the camera gui look like - I bet it will be fine.
NVR - DHI-NVR4108-8P-4KS2
IPCs - 2431T & 5442ZE
The NVR is on its own VLAN without internet access.
The Raspberry Pi is on the same VLAN an the NVR and the main VLAN (with internet access).
The Raspberry Pi is responsible of:
1. NTP server
2. Subscribing to events - from the IPCs and pushing to me to Telegram (Raspberry Pi reaches the IPC using the NVR - virtual host feature)
3. Notifying me if a camera goes offline or its time is out of sync with other IPC or Raspbberry Pi
The raspberry Pi supports Vlans, so with one physical port, it can be on both Vlans.
I can try with power supply, but I'm bit lazy to do electric tape sealing and dialectic grease again (will take me half a day, to remove and install and check with passing cars).
You don't have to take the camera down - simply unplug from nvr and use a poe switch or poe injector to power it up.
What does the live view look like with monitor connected to nvr?
Reactions: sebastiantombs
Seeing live view from NVR and from camera gui should hopefully pinpoint it isn't a setting in the camera but rather an issue somewhere else in your system.
I'm seeing similar artifacts on a 5241 that stays in color during the day. Not quite as bad, but they're there.
Did some testing and while I dont have the answer, I have noticed some things. Now some will say it doesn't matter because we're not making Hollywood movies, and I get that. But it is an interesting issue that i dont see on 5442's...
Here's a couple of samples
My normal daytime LPR settings on a 5241 Z12
8192, CBR, H.264h and 30FPS
Notice the artifacts/blur immediately behind the vehicle. They clear up within 3-5 frames or maybe 1/2-1 second. There is also some showing up on the bottom half of the vehicle
Before >>>> Red outline area >>>>>> Gone
HOA Entr_EntTag_main_20220806171337_@3.jpg HOA Entr_EntTag_main_20220806171340_@3.jpg HOA Entr_EntTag_main_20220806171343_@3.jpg
HOA Entr_EntTag_main_20220807115424_@3.jpg HOA Entr_EntTag_main_20220807115430_@3.jpg HOA Entr_EntTag_main_20220807115434_@3.jpg
So my first assumption was Gain being auto adjusted by the camera due to the 0-50 range I had set. So I fixed Gain at 30/30. Actually saw some improvement, especially on the car itself, but the trailing artifacts were still there
HOA Entr_EntTag_main_20220807121523_@3.jpg HOA Entr_EntTag_main_20220807121531_@3.jpg HOA Entr_EntTag_main_20220807121534_@3.jpg
Video from that one. If you run it slowMo or frame by frame, you'll see the artifact trail immediately behind the car in the grass
View attachment HOA Entr_ch3_20220807121523_20220807121537.mp4
So next I thought I'd play with Iframe interval. Typically I match Iframe interval to FPS. But I had seen some analysis about extending Iframe to 3-5x that of FPS, So I set it at 150 with my normal 30FPS framerate.
Still there but less pixelization and seems to dissipate faster?
HOA Entr_EntTag_main_20220807131007_@3.jpg HOA Entr_EntTag_main_20220807131011_@3.jpg
Video (Go full screen)
View attachment HOA Entr_ch3_20220807131001_20220807131017.mp4
And another without companion pics but its noticeable at full screen slomo or frame by frame
View attachment HOA Entr_ch3_20220807132851_20220807132905.mp4
