achalmersman
Pulling my weight
See my example video in this thread
Severe Focus Issue with IPC-HFW5231E-Z12
Sent from my VS990 using Tapatalk
Yea thats the worst part. Mine is changing focus on its own in the middle of the day without even a screen change. To the camera its a steady scene of stone and grass and road and BAM it shifts focus and stays out of focus
Do you have PTZ enabled in BI for that camera? I was inadvertently causing zoom to occur while navigating around BI until I disabled it.Same here, except that it even starts out-of-focus. Manually focus, leave it for a while, come back and it's out of focus. But only when zoomed in quite a bit.
guys, i was thinking of going with the Z12 to get plates cause we're getting blasted by mail thieves...you think this location will be good/acceptable? will this be a good cam for the job??...I'd need to zoom in of course..
the focus issue does seem to be putting me off...should I go for Z12e?....any alternative you might recommend?
Thanks!
That's a tough call, you'll probably have to force manual zoom by using adjustFocus to get past your pole. You should check it against the IPVM Camera Calculator V3. I assume you have different camera on the mailbox?
While watching someone run off with your mail can be entertaining a better solution (than LPR) is to get a locking mailbox.
This camera is crazy good for watching the license plate. Any guys in other country can watch the plate like this pic?
impressiveI'm using the free version of OpenALPR for now.
By exporting the data out, every 2 days. The only data you will not have is the pictures.Assuming you are still using free Open ALPR how are you retaining data after 2 days?
