Way too much contrast, that's why the bright headlights. 60% would be betterOk, so I've been recording at day and night for a few weeks now. I would say that the daytime is really well dialed in. I did move my camera to a new position to get closer to the plates. Now I'm at about 110 feet.
I'm still having a little trouble at night. I would say that I can read almost 90% of the plates by eye, if I step through the frames 1 by 1. Feeding them to PlateRecognizer is a different story.
I'm using a secondary IR illuminator and at night the plates light up really well. But I'm struggling with headlights and tail lights, even with HLC up to 100.
Just curious, what's the max distance some of you guys are running for LPR and getting clear picture? I have one camera set up right now at 130' or so but off angle. I'm getting pretty good shots so far 90% of the time. I need to cover my street going to opposite direction and have a choice to run another one at 140' or so at the same off angle or try to run it almost dead on at the stop sign at the end of the street but that's closer to 200'-250'... Would I be able to get anything at that distance? I don't think I would have to rely on the IR since there is a street light down that way. So, 45 degree angle at 140' again or 0 degree angle but 200'+? Thanks!
I have shutter at 1/1000, Gain at 10-48, Iris at 33, Grade at 33. I also have an IR light to help.
It is the one, that has 15 degrees.![]()
25.17US $ 26% OFF|100m Ir Distance 15 Leds Ir Illuminators Ir Infrared Light Led Cctv Camera Night-vision Ir Fill Light For Cctv Security Camera - Cctv Fill Light - AliExpress
Smarter Shopping, Better Living! Aliexpress.coms.click.aliexpress.com
Definitely you need HLC.
Believe me, I have a quite a few myself, including a 59225, LPR, 2x 5231. This is just at the front, on the side next to the LPR I have a cheap 4231R-Z, porch 5231-R-ZE and a 5442 as a bird house, Ring doorbell.
My light definitely makes a difference, but I want more.
I have purchased some LEDs + lenses, and some power source, but it is very hard to buy all the right components. I will have to come up with some weatherproof housing as well.
At least I'm experimenting with this setup. Not going overboard, just trying out some 5W LEDs.
