	Should I zoom out to 85% even though it will have a wider FOV?Anything after about 80-85% zoom and the camera wont hold focus very well. This may be why you noticed the cam zoom by itself.
1/1000 is pretty standard, even 1/2000 if the vehicles are moving fast, say over 25mph.
Those images look kinda dull, not sharp. What bitrate are you running?
There are actually some pretty good shots, I just posted the worst ones. I think it may be focus issue?Anything after about 80-85% zoom and the camera wont hold focus very well. This may be why you noticed the cam zoom by itself.
What that CBR and VBR and what they do?
Is this light very noticeable for human eyes? Right now I can see the red dots when I am coming back home and most people probably can tell that the camera is pointing directly at the road. I don't want to attract any more attention is unnecessary.OK, I'm back.
I have added the focus.
At night is very good now, but the transition from day to night is still bad.
This is with the profile Day/Night in the GUI.
I will try Normal now.
The whole image lights up in this profile.
I will be back, after having some recordings.
The added IR light works very well. It is the 15 degrees one.
25.46US $ 24% OFF|100m Ir Distance 15 Leds Ir Illuminators Ir Infrared Light Led Cctv Camera Night-vision Ir Fill Light For Cctv Security Camera - Cctv Fill Light - AliExpress
Smarter Shopping, Better Living! Aliexpress.coms.click.aliexpress.com
