aristobrat
- Dec 5, 2016
- 2,979
- 3,180
are you certain its the motion that is triggering BI not the PIR?Just wanted to follow up that I had no luck with that. Even with no schedule, it still triggers BI. It's persistent. lol
99%. I can tell when the camera's motion detection is enabled (in addition to PIR) because the top left of the image is a street and as cars drive by, this camera triggers. When only PIR is enabled, the camera only triggers when someone's in the porch area. I'll shoot Ken an email.are you certain its the motion that is triggering BI not the PIR?
If so email support.
This seems to be a really good camera , big seller! I plan on buying once stock is replenishedThis model stock use up, new stock will be ready 2 weeks later.
Email support. The more people who ask the bigger chance he will work on it. Provide remote access to the rtsp and http in the email.Got my cams yesterday thanks @EMPIRETECANDY
@fenderman same here cannot get the talk audio working. Have time to work on it this week if you want me to try anything. I followed Ryan's screenshots from the Lorex thread and no luck.
Got a reply back from Ken mentioning that he will have to circle back around to this once he's completed some other major projects under development.are you certain its the motion that is triggering BI not the PIR?
Sweet! Thank you @fendermanKen accessed the camera, talk audio will be supported in Blue Iris with the next update.
No idea. If it doesn't, all you need to do is open a ticket provide direct access to the camera and he will get to it. He is backed up and it took him 4-6 days to respond to emails.Sweet! Thank you @fenderman
Do you think that will work for the db11 as well?
Cool.. I'll see if this works and if not go that direction.. Thanks and I'm sure the entire forum appreciates your effort brotherNo idea. If it doesn't, all you need to do is open a ticket provide direct access to the camera and he will get to it. He is backed up and it took him 4-6 days to respond to emails.
-g --user username:password --digest "http://192.168.1.XXX/cgi-bin/configManager.cgi?action=setConfig&MotionDetect[0].Enable=false"
So I tested this using onvif device manager and the same thing happens. It enables motion detection when it logs into the camera via onvif. This is a bug that dahua needs to address. @EMPIRETECANDYI am having a little bit of a struggle with having BI only trigger when this camera's PIR Alarm triggers.
Initially, this configuration works great:
BI:
Video > Configure... | Select "Get events with PullPointSubscription"
Trigger > Sources | Only "Camera's digital input or motion" selected
CAMERA:
Setting > Event | Only "Alarm" > "PIR Alarm" is enabled
The struggle I'm running into is that after that's all setup and running great, if I do anything that makes BI disconnect/reconnect to the camera (like save an edit to the camera's properties in BI or restart the BI service), somehow "Motion Detection" gets enabled on the camera.
Needless to say, with both "Motion Detection" and "PIR Alarm" enabled on the camera, BI gets triggered a lot more than I want. If I go back into the camera and disable "Motion Detection", everything is good until I do something within BI that causes it to disconnect/reconnect from the camera... then "Motion Detection" on the camera gets re-enabled.
The lens is 2.8 mm wide angle, and the IR is significantly weaker. If you want an eight megapixel camera look at the 2831 with the 1 / 1.8 sensor... Or see IP cam talk Hikvision cameras with half inch sensors... There are already comparison shots in those threads.how do you guys like this cam vs. the "classic" 5231r-ze?....I know the 5231 major benefits are being varifocal and low-light...but I'm looking for cams with better image quality/higher MP res for next install...any thoughts? any other cam with higher MP you'd recommend?
there is another thread with looneys review. You can disable the flashing if you wish. You need lots of light for this camera. This camera is suitable for indoor use, front door or a driveway warning camera to scare off door checkers. If you want good low light images look at the other cameras with larger sensors.Would it be possible to get a video from this camera at night when the light is flashing? Does it switch back and forth between color and B&W? Does it make the video not usable once its been triggered?
It seems like this is perfect for active deterrence, but should definitely plan for a separate camera in the same area for overall video quality. Any triggered samples from night would be very helpful. Thanks.
