Shockwave199
I believe if you right click on the camera in device, choose advance configuration and in that submenu should be the option to get into the camera menu. From memory anyway. Hope it works out for you.
Good point, im going to give it one more chance...if it happens again, im going to first try adding a switch, if its still unresolved im going to re-crimp it....check the cable ends really well, a bad crimp could cause this issue.. a bad connection could heatup slowly after IR is turned on and lower the voltage to a point where the camera hardlocks.
