Hi Andy,
I'm hoping someone can help me determine whether this is a configuration issue or a hardware problem with my IPC-Color4K-X S2.
The issue is a subtle but noticeable motion stutter. It feels like the camera randomly drops frames or momentarily slows its frame cadence. The image quality itself is excellent—the problem is purely the smoothness of motion.
The important part is that I've confirmed the same behavior in:
Camera web interface
VLC
Blue Iris
OBS
So I don't believe this is an OBS or Blue Iris issue.
Things I've already tested:
Updated to latest S2 firmware
H.264 and H.265
CBR and VBR
4K, 1440p and 1080p
24 FPS and 30 FPS
Bitrates from 4 Mbps to 12 Mbps
50 Hz, 60 Hz and Outdoor anti-flicker
Manual exposure (0–4 ms shutter)
Smooth Stream settings
Disabled metadata tagging
Different Ethernet cable
Different PoE switch port
NVIDIA Studio driver
I also have two EmpireTech turret cameras on the same TP-Link TL-SG1005P PoE switch (65w with up to 30w per port), and those cameras are smooth.
The bullet camera is the only one exhibiting this motion behavior.
I have a short video demonstrating the issue if that would help.
I'm at my wits end, and I'm starting to believe I have a defective camera. A smooth 30fps is important to me because not only do I use these as survellance cams, but I stream online. (they are mounted all around my semi truck)
Best Regards,
Paddy
Homestead Express LLC
VLC
Blue Iris
OBS
H.264 and H.265
CBR and VBR
4K, 1440p and 1080p
24 FPS and 30 FPS
Best Regards,
Paddy
