IPC-B52IR-Z12E S2 vs axis p1455 LE
thlong
Joined
May 14, 2024
Messages
29
Reaction score
2
Location
ca
Hello,
If I only use the control setting that comes with the camera ( access through the web browser), saving video/image directly on the cam (micro sd card?). Which cam is better at LPR , which cam is easier to setup? Consider the cam points to the street at about 45°, 30ft.
TIA
wittaj
Joined
Apr 28, 2019
Messages
25,681
Reaction score
50,136
Location
USA
You are comparing a 64mm varifocal to a 9mm varifocal and that will result in greatly different capabilities.
Most here would say to go with the Dahua OEM as there are many of us here that can help you dial it in. Not many people here use Axis, especially for LPR, as it is overpriced for what is needed.
If you are truly at 30 feet (most people under-estimate the distance), then you can get by with a cheaper turret like one of these:
richardgohth
Joined
Jun 23, 2017
Messages
123
Reaction score
40
Location
Singapore
Hello,
TIA
setup both are difficult,
axis has an "expert" mode that is even more complicated.
I have good results with axis camera
check if the lens zoom fits your requirement
sensor shld be the same
wittaj
Joined
Apr 28, 2019
Messages
25,681
Reaction score
50,136
Location
USA
I don't know if I would call it difficult, especially if you have been in Dahua GUI.
My friend just got the z12e and I set it up in a few minutes. We have tons of baseline settings used in the LPR subforum.
thlong
Joined
May 14, 2024
Messages
29
Reaction score
2
Location
ca
I'm new here. How to get to the subforum?
Top
