IPC-4k Turret stutter video
Movies are shot at 24FPS and projected on the big screen seem ok to my eyes, so anything more than that is a waste on my mobile or monitor that is a fraction the size of the movie screen lol.
But I don't have the eye candy delivery people you do either:lmao:
thanks for the response. Some answers below…
i appreciate your input and want to work toward a solution. I think it’s clear I know I’m not making a Hollywood movie, and my expectations are honestly not unreasonable as others and even yourself have even said this camera is fully capable of 4k30. it’s obvious you’re an experienced member here so I value your input and hope we can move on from the unreasonable ‘Hollywood‘ expectations bit
my BI database is on a pcie gen 4.0x4 nvme ssd and I’m recording to a raid1 array of two seagate Skyhawk surveillance drives.
i have no antivirus software other than windows defender. I have not made any changes to windows defender defaults. Please share if there are specific considerations for windows defender.
I will have an opportunity to test this next week and will provide updates with results.
It’s on a dedicated VLAN.
The camera is not doing anything on-device except encoding. No IVF, motion detection etc. Thats all handled in BI. And my CPU does not break a sweat for any of the motion detection or even AI processing (which I disabled for testing and troubleshooting).
thanks for the continued discussion
You must read the Blue Iris help file .. You can also perform an easy test as I explained... With an SD card
You need to exclude BI folders and video folders from Defender. That could certainly cause it.
Yeah I was on the 30FPS as a NOOB once too LOL. And then watching how fast storage was disappearing and that I only needed the ability to get the clean capture of a perp, I optimized my system towards that goal.
wittaj, thank you for some of the helpful tips provided. mixed in with those helpful tips, however, is some very strange insistence that 30FPS is for noobs, for hollywood, is an unreasonable expectation, etc.
i would encourage you to please consider that those comments are not helpful in diagnosing a technical issue. and, as evidenced by other forum members' posts here, you are wrong in that regard. your specific recommendations for troubleshooting have been helpful, but the rest of your commentary in this thread could lead newcomers like myself astray. and, fwiw, i am a newcomer to the forum, and a new user of BI, but i am not a newcomer to hardware, software, networking, photography, videography, and the like. newcomers to the forum, or the software, may have more experience than you in these areas.
...in any case,
i have seen improved performance after making an exception in Windows Security. EDIT: Please see Post 46 for an update; this did not appreciably improve performance on my machine. YMMV.
For anyone in the future wondering how to make this exception in Windows Security:
1. In the start menu, search for "Windows Security"
2. Select "Virus & threat protection"
3. Under "Virus & threat protection settings" select "Manage settings"
4. Under "Exclusions" select "Add or remove exclusions"
5. I excluded the "Blue Iris" folder within my Program Files directory, as well as the "New Footage" folder.
i mentioned in an earlier post i will perform this test next week and will update the thread. i have seen improved performance after excepting BI Program Files and Storage Locations from Windows Security Virus & Threat Protection, but will still perform this test as i now have a vested interest in demonstrating that 4k30 is reasonable, usable for home security, and achievable.
No one said its not achievable or usable. it is not necessary and often foolish if your end goal is to maximize surveillance capability. It takes double the storage as 15fps if as you would need to double the bitrate to achieve the same recording quality. It will also consume double the cpu power. In 99.9 percent of case use it provides no benefit other than curing OCD. It is always better to have longer retention - even if you think you will never need it. You will rarely see 30fps in a professional setting. In fact up until recently the max for many high res cameras was 20fps.
If you dont read the help file you will simply set your self up for failure as you have here.
Moreover, when someone spends time providing a FREE solution that was necessary because you failed to read the instruction manual, there is no need for passive aggressive bullshit like "ut the rest of your commentary in this thread could lead newcomers like myself astray "
You are an amateur who was given proper advice. Stop spitting a gift horse in the mouth.
It isn't some strange insistence that 30FPS isn't achievable, it is just that in most uses cases it isn't needed and that is an early troubleshooting step we do to try to find the root cause.
Do a search here - I am by far not the only one that suggests/recommends not running 30FPS when someone starts a thread about stutter video. Unlike you, they had already read the help file and had excluded BI and associated files from the antivirus and have done everything else but was still having stutter issues and dropping FPS fixed it. I just happened to be the first one that saw your thread.
Many people here have seen their system or video get stable when they dropped the FPS, as you readily admit it did for you. I also provided evidence from a camera that shows CPU load and how FPS increases the CPU load and it would become unstable. That is real world experience versus the marketing of a camera.
Or the boobie camera where folks have found to use any of the AI like face detection, you need to drop the FPS to 5FPS even though the camera is rated for higher...
It isn't as much commentary as it is real world experience by many folks here.
Plus the Optimization wiki, that was developed by folks with years of BI experience, strongly suggests 15FPS.
So yes, it is important for people to know that in certain situations and certain cameras, you can certainly overload the processor of a camera and not be able to achieve every rated spec.
Other than smoothness of video, I am not aware of anyone that has proven 30FPS was a benefit over 15FPS for these types of cameras. Even at 30FPS it still will not be able to do what a Go-Pro can do for the same FPS and field of view.
So we had what 2 or 3 folks chime in 30FPS works for them. One uses an NVR and the other BI and said he uses 30FPS for smoothness of wildlife. That is by far a minority here. Most here do not run 30FPS for the reasons I pointed out.
As @fenderman points out, to maximize surveillance capability, 30FPS really isn't needed. If you add enough cameras and want to do BI AI with each one, even your screaming machine will get bogged down running every camera and AI at 30FPS...
Here is more anecdotal personal experience.
Early on in my migration from NVR to BI, I noticed the my LPR camera wouldn't trigger in every instance (I knew this because the overview cam triggered and the LPR camera didn't)
So I noticed while watching it live for an extended period that for my license plate camera (which is zoomed in tight to the road to read plates), I watched it not trigger for a big ole yellow school bus, but then trigger for a tiny 2-door car the next minute that was driving slower and then miss the same car coming back 5 minutes later! Sometimes we are unaware of issues unless we spend a fair amount of time watching it live under every scenario....
For this plate camera, I was running a fast shutter to capture plates, but also had the FPS at 30 FPS thinking that would be better. When I knocked it down to 10 FPS, Blue Iris motion started capturing that bus and other vehicles it was missing. I think the motion algorithm for a tight field of view was having difficulty with the faster FPS as there wasn't as much of a difference comparing frame to frame at 30FPS to 10FPS. Another real world example of how lower FPS was beneficial. A vehicle is in and out of my LPR field of view in under 0.5 seconds and I now get trigger alerts and capture every plate at 8FPS (yes I dropped it even further for longer retention of LPR images).
Regarding your comment about knowing about photography and videography, you might have to forget what you know about DSLR and high end photography cameras LOL as you play with these. Almost everyone that has come here with experience in DSLR cameras struggle with these cameras. Every one of these cameras have more processing of the images than a DSLR camera. Some are worse than others. Then there is the compression of the video, etc. Turn off NR on one of these cameras and you will see how much processing is used.
You will find a BIG difference between photography equipment and these cameras. Things like trying to match focal lengths are tough because it may be crystal clear on high end DSLR and not be clear with these types of cameras. Digital zoom works better on DSLR cameras than these. The sensors and optics just are not at the same level. These cameras are designed for 24/7 use with abuse from the elements. DSLR cameras are designed for a different working environment and purpose. Hang a DSLR camera outside and see how long it lasts LOL! But the quality would be better for the time it was working (but also a lot more storage needed too). Heck an iphone camera is probably better than most of these. But it won't last long outside LOL.
Remember these are surveillance cameras, not DSLR cameras, so you have to check your expectations. For example, you can see individual hairs and skin pores with DSLR photography equipment and you won't with these kinds of cameras. These are for a different use and different expectations.
  • Sensor Size - a full frame DSLR sensor size is 864mm^2; whereas a 1/2.8" sensor popular on many cameras would be 20mm^2, so the "real" camera can collect over 40 times more light than a surveillance camera. And this doesn't even account for less light available for an 8MP versus 2MP for the same size sensor.
  • Shutter Speed (Exposure) - Taking a picture with a "real" camera, you can slow the shutter down to 1/2s or longer for a nice clean picture of a person not moving. Perps rarely stand still and we need a shutter of at least 1/60s to minimize the blur.
  • Aperture - With a "real" camera you focus on a specific part of the field of view, while a surveillance needs to focus on things in the foreground and background, which means the aperture is smaller, further compounding the light issue.
  • Compression - A single 8MP image from a "real" camera could be upwards of 5MB of storage. In surveillance cameras, if you record at 15FPS, every second of video could be 75MB or more, which could equate to 6.5TB per day per camera. Obviously most are not going to have that kind of storage, so lossy compression algorithms are used to reduce storage and network bandwidth requirement, and that can add noise.
  • Environment - a "real" camera is used mainly under ideal conditions, whereas a surveillance camera is going 24/7 in every type of element, so the design and size impacts its capabilities.
Maybe as you move along the journey you too will realize 30FPS isn't needed in most instances for these cameras, or maybe the troubleshooting I provided allows you to continue to run at 30FPS.
Reactions: JDreaming
Have you tried running the System with Raid 1 turned off to see how it behaves?
If not you should, so you can check that off your list.
I have 19 cams on 2 HDD's but rather than go for redundancy, many of us go for splitting the Write load across 2 disks for better system performance.
Some one mentioned evaluation version.
I hope he's not running it in eval version.
AS I recall, it does not perform the same as the full version ( at least in my experience) My CPU % higher. but 2 years have gone by since I thought about this.
Just for an example.....I put 2 of my 5442-z4 bullets on max frame rate 30 and max Bits per second 8192.
Then i converted a Minivan video capture to .mov.
Meanwhile the system is recording 9 other cams eating this much stream...
heres the video...
here's the other one maxed out.
SO my system is busy....I'm watching Youtube, recording 10 cams and playing back one cam @ 30FPS ( sub and Main)....and everything is smooth.
And if i freeze frame i can read the plate.
and here is a 10 FPS capture bfore i changed the settings.
I get what i need at 1-12 FPS on my LPR reading during the night, and enough useful data on day time shots.
I still got his plate.
Intersting. The cam knows it's limitations.
It will not make available Subtream FPS above 4 with mainstream maxed out. As soon as I got t olike 20FPS it makes available the remaining selections in the drop down menu
heres the video...
If we are being honest, I see a stutter in your 30FPS examples... (or it is a stutter from the net)
