IP Cam Talk Custom Community DeepStack Model
Just wanted to say thank you to everyone for assisting me with setting up Deepstack on my computer. I appreciate all your responses and for taking the time to explain certain aspects of setting up the software and how to best configure it. I was able to get everything set up this past week and it is running perfectly. Still need to make some more adjustments on the camera's motion detection within Blue Iris, but otherwise working as it should. Truly appreciate all the responses and taking the time to assist me.
Any ideas why I am not able to detect raccoons? Using the latest animal and combined models from first post.
See below, 5 raccoons mulled about my patio and never got a trigger. Note - my dog triggers this camera consistently.
What mode are you using, if you are not using High try it it might improve the detection also you might want to increase the contrast setting in the camera.
A good way to tell if you have enough contrast is to have a black object in the FOV and if it looks gray you need more contrast. If the object is gray increase the contrast small increments until it looks black but not to much that the rest of the image is to dark.
Thanks for the suggestions. I was on AI-mode "medium" and switched it to "high". Now, I am pretty sure I have the BI/Deepstack setup properly because I see in the BI-AI-log window under animal mode: bird, cat (see images), but never a raccoon. I guess that leaves improving my image quality by tweaking the contrast or a new cam.
I've been quite happy until now with the default DeepStack settings in Blue Iris, but I need to do something with our deer problem. I believe I've configured BI correctly to use MikeLud's combined.pt (placed the file in the MyModels folder). From what I can see the combined model is being used, but the deer is detected as dog/cat/bird. Is there something else I should check regarding settings in BI, or is it the camera that needs to be tweaked? Detecting persons etc. is working flawlessly.
Reactions: kc8tmv
I have the same problem with deer! Combined, dark and animal models ALL have no idea what a deer looks like for me. Using “high” mode also.
Deer are identified as dog, cat, fox, anything except deer.
My thought is simply there are not enough deer images in the models.
One of the reasons is image count when I trained the model I only had about 50 images. I do have more images of deer's to add to the models.
The next updates to the models I am going to only have 3 labels in the combined model "person, vehicle, & animal". For the animal label I will use all types of animal to train the model. I will keep the animal model with individual labels.
Please don’t take my comment as a “slam”! You just had what you had! Thanks for the hard work.
The link with more details on the deer model. The label "to confirm" is lowercase "deer"
@Freddan101 Are you using "High" mode as @MikeLud1 showed above. AI detection of animals is not perfect. For example, two nights ago AI thought a person was outside. It was a spider instead.
Yes, saw the post and tested to set to "High" but same result I'm afraid.
The person that gave me some more deer images made a deer only model, this model was trained with about 600 images. If anyone wants to try it out see attached.
Excellent, thank you. I will try it out immediately. If you need any more deer images, just let me know.
Animal PT said they were squirrels, combined PT said they were dogs, dark PT said they were cats, new deer PT didn't find a thing.
Works fine for me never needed to touch the brightness contrast catches People fine and cats, foxes did'nt want any cars so left that out no headlight issues. Only thing I had to change was add People instead of person my setttings are:View attachment 121396
Aha! I've been trying to get the combined model working on a Jetson Nano for a while now. I finally see the Blue Iris talking to Deepstack.
Deepstack shows 500, running the combined model, Blue Iris alerts, but just shows "nothing found". No errors! I tried person, Person, but I didn't try "People". I'll try that tomorrow.
