IP Cam App
Sep 18, 2026
2
1
New Zealand
Hi, Im using Cam720 and wanted something with a little better resolution (if possible) on my SD card for play back....(nHD at Moment 640x360)
I have tried thingino on my 3rd cam but the software ive tried does not suit,
I need it to record full time to the SD card and have audio and a time line i can scroll through to see motion detection's.....
(basically the same as Cam720) TinyCam does not have audio in background mode and the other apps dont allow you to try the full features before purchasing....
Do you guys have any thoughts on apps I can try ?
