EMPIRETECANDY
IPCT Vendor
Color pic make people happy
8mp black and white also very sharp.
That's quite weird. A real puzzle. Some quirk of the NVR firmware probably.Conflict details.
G2 on port 10 starts, 2335 on port 2 drops off.
G2 connects to port 10 but picture and recordings appear on port 2.
2335 on port 2 reboots changes IP address but picture and recordings appear on port 10.
Now the war starts one on other off. Reboots and swap on/off.
Especially as you've checked out a possible most likely cause.No camera has the same MAC Address.
Not that surprising as there have been multiple changes and extensions to those smart events.The NVR is now unable make changes to line crossing and intrusion settings at the G2 camera. This is not big deal as there is addition setting available only via the camera direct.
Have now update the G2 to IPCH_EX_G3_EN_STD_5.5.153_200730 firmware
Presumably by 'direct' you are referring to 'Virtual Host' ?
Just recheck the camera. Have used firmware V5-5-150_200927.That's what I was going to do. Until @watchful_ip advised me it's not the correct firmware.
This is what I used :
Yes it can be turned on and offCan the led light be disabled on this camera ? I don’t want to use the led light at all.
It has a built-in microphone - but it does not have a loudspeaker.Does this camera has two audio? So you can listen and speak through the app?
I do agree that by default the camera produces quite a vivid image.But something the image is a bit over bright. How do I set a auto brightness or something?
Yes, it's missing from all the stock firmware that Hivision are publishing that I've seen.But i'm missing the event to trigger the white LED's by an event.
