DarkHelmet
- Feb 26, 2017
- 192
- 76
app update didnt fix NVR pushes for me.Gdmss plus has got an update on the 22.09. therefore I switched back my firmware, could you try If something changed?
In gDMSS and iGDMSS you always see all type of possible events. It doesn´t cares about which one you are using. This is a little bit senseless of course and doesn´t make it handling easier.Does the IVS in the iDMSS related to the camera's IVS?
It seems to me that the iDMSS IVS does not use the intrusion area drawn in my camera's IVS setup; and you are allowed to select totally different type of IVS than your camera setup.
You need an nvr to get the clips sent to DMSS.
The phone app (DMSS) gets the IVS clip push that is recorded on the NVR.
In my experience, the phone can get a notification that the IVS was triggered but you won't get a clip of it unless you have the NVR. And currently, nobody can get clips from the NVR since it's broken again.
I was talking about pushing the video clip. I've never messed with snapshots. Have no idea how/if they work.
Thanks for the heads up!We have a new firmware for nvr 5xxxx and 4xxxx.
DAHUA RECORDERS HACKED
Maybe a try also for this issue.
I know this has nothing to do with push, but can someone check the Android or ios or both to see if the save icon is there in device manager when you go into edit for a device? It's missing from both for me with the latest app version. Thanks for checking if you can.
didnt work for meThis old vision will be working Android.after setting if u want to change you need uninstall then install this app again then will be good.
