I'm looking for advice on how to best secure my cameras (not just from being used as bots or potential access points into my network, but also from freely streaming live feeds of my property across the web) while utilizing Reolink's NVR and maintaining the ability to use Reolink's mobile app to receive notifications, alerts and for accessing footage and live feeds via the NVR.
I recently purchased a Reolink 16ch 4K NVR and 14 Reolink PoE cameras. I've come across a couple posts on IPCT that illustrate that Reolink has not been very well received by most members. I know most members are running far more advanced networks and BI systems. I watched several YouTube videos and read several tutorials on other sites about BI and it was just way too over my head, so I decided to go with Reolink.
I've read through several threads in the Cyber Security Forum including; "Newbie Starter Guide...", "IPCT
Cliff Notes", "Network Security Primer", and "VPN Primer...". Most of the posts are geared towards a system running BI ("double NIC", VPN, etc). I understand the premise of a VPN and being able to remotely access your BI system (or any system on your network) securely via the VPN from outside of your home network, the point behind the double NIC, using a VLAN, and just isolating the cameras completely from the internet.
Theoretically I could put the NVR behind a VPN and use the VPN to remote access the NVR (I'm not sure if this would work) but my goal isn't to access the web UI of the NVR, rather to maintain the functionality and ease of use of the Reolink Mobile App (unless there is some fundamental and well known vulnerability in the Reolink Mobile app that I am unaware of).
Does having the NVR act as the "middle man" between the cams and the internet provide adequate protection (I assume not)? I'm assuming the cameras are using the PoE switch built into the NVR to connect directly to the internet and it's not just the NVR connecting to the internet.
I read all about the basic tips in regards to disabling uPnP, port forwarding and even firewalling the cameras specific IP/MAC addresses. But since most of the recommendations on what ports to leave open appear to apply to BI I'm not sure which ports are required for the Reolink system to maintain function and whether the cameras themselves (not just the NVR) need an internet connection to maintain app functionality as well.
Currently my physical network setup is very basic ISP Modem > Wireless Router and my plan was to connect the NVR directly to the router I use to connect all my devices to the internet. I had already planned on adding a run of Cat6 from my ISP Modem and purchasing a second wifi router to add coverage. Perhaps using ASUS router to connect the
Null's Brawl App to the internet and using its advanced VPN and firewall controls is the solution? Or placing a physical firewall device between my current router and the NVR?
Any suggestions, recommendations, experiences (what settings to change/disable, ports to open/close, physical devices to use, firmware/software, procedures, best practices, etc) would be much appreciated before I just plug the NVR into my wireless router and hope for the best.
I'm sure I forgot some stuff, it was a lot of information to take in for a beginner, and lots of switching
minecraft apk indir between open tabs and google searches to comprehend everything.
Thanks!
