Go to the Day/Night option (3 down from shutter/exposure setting) and change it from auto to color.
I don't have a COLOR option. Everything under the drop down is grayed out in every setting.Go to the Day/Night option (3 down from shutter/exposure setting) and change it from auto to color.
I am saying MODE is grayed outYou are looking at the profile - look at MODE on that page - it is set to auto - change it to COLOR
I got the color back along with a shitty imageUnder Profile Management, change Day/Night to Full Time and then you should get access to it.
It seems crazy that I have to do anything. Two weeks ago I didn't have issues with noise. The only thing that has changed is the weather. It went from 65 to 6 degrees. All this noise came up when the weather turned cold. I'll see about 1/60... There is really quite a bit of light on the barrel. Enough to cause a shadow on the ground and the barrel is 16' off the ground. This is frustrating.The faster the shutter, the more light is needed.
The slower the shutter, the less light is needed, but more chance for motion blur.
That is why the camera went into B/W because it believed for the shutter speed and available light that there wasn't enough for color.
So if you can live with some blur, slow the shutter down. Try 1/60
Look at this from last year. I don't mess with the settings. The video isn't as good now as it was last April. Let me know what you think...thank you! And look at how much more you can see below the barrel in the video. And I actually raised the barrel about 6" Thanksgiving day so the barrel is a tad closer to the light.If this is a live stream the quslity hasnt changed in 2 days. Almost as if none of your changes are being applied to the stream
Nest Cam – Okie Bird Cam
Even my platform feeder cam looks better than this cam and it's a IP5M-T1179E It's here under bird cam tab- Okie Bird Cam – My WordPress Blog I'm going to see what it's settings look like...If it is LED lighting, some cheap LEDs don't get as bright when it is cold.
This is video from Jan 4th. The video look much better here than now...If this is a live stream the quslity hasnt changed in 2 days. Almost as if none of your changes are being applied to the stream
3dNR wasn't on. I know I selected it but I must have not hit apply. I think that fixed it. YAY Thank you!Nope they dont. 3 DNR is OFF should be ON
I just added a video of Jack coming in this morning and evening. I'm thinking there might be too much blur when my owl moves in low light. These are the settings for this cam in the web UI Please let me know if there is anything you suggest to improve my video. Thanks again for all your help.
