CCTVCam
- Sep 25, 2017
- 3,106
- 4,012
Generally, no, there's no direct ISO adjustment that can be made in these cams. You do have gain adjustment which can be used in a similar way with a similar result of increased noise at higher levels.
Likewise, no direct aperture adjustment. Some cams do have an "iris adjustment" (e.g., 5241E-Z12) but not commonly and in some cases it's not a physical adjustment; rather, a digital simulation. In either case, not an adjustment that's practically used much other than maybe some specific cases. Most of the IR or color cams that you're looking at won't have either.
Yep the OP needs to think video.
For video there's no such thing as ISO but Gain. It's pretty much the same thing. What Gain does is electronically amplify the signal from the sensor to retreive more detail ie the weak electronic signal representing the picture that would otherwise be lost. The disadvantage of gain is there's no way for the camera to know what is valid signal and what is spurious induced current (at these levels we're talking very weak signals for both). The result is both get amplified and become a part of the picture. The part of the signal that represents bits of the picture, when amplified enable you to see detail you'd otherwise be unable to see and thus information that would be discarded on playback as being too weak. The disadvanatge, is the more you up the Gain, the more you amplify the false induced signals and currents in the sensor and these appear in the final picture as Grain ie dots, coloured aberations or in the case of movement, ghosting as decaying signals from where objects used to be are also amplified and still exist long after they should have been discarded. This is why too much Gain is bad. However, a little gain can help. It's all about moderation and accepting Gain cannot perform miracles. All Video cameras not just CCTV use Gain instead of ISO but they're much the same the thing for practical purposes. I'm sure a camera expert will jump in from the internet and tell me I'm wrong, but it's for practical purposes not exact theory.
Aperture is fixed on most CCTV cameras as these are simple cameras with small brains.
Also, you cannot disregard shutter speeds effect on picture at night. Even a poor camera on a poor sensor can look decent with a slow shutter speed and plenty of balanced gain to let lots of light in. That's how marketers sell many poorer cameras. However, the 1st time something moves it will be blurred or ghosting and unrecognisable. You need to run a fast shutter even at night to freeze motion. I run 4ms on both my cameras which equates to around 1/240th from memory. Below this I've found a person can blur. However, to do this I need some background light at low level (I use a 5w led wall light with my cameras) and some gain (=50) which is sufficient to give a clean image with enough light but doesn't cause artefects, Grain etc (It will amplify aretefacts with insufficient light. Hence the importance of getting the balance right).
I'd take Wittaj's advice and look at a 5442 as 1st purchase. Buy one varifocal and test it to see if you're satisfied before buying others. You can also use it in different places to test the focal length required although varifocals always give more flexibility for only slightly moire expense. Also note there are a lot of 5442 models and some older ones are on smaller sensors. I leave it to others to advise the best models in the range. The 4Kt's are very capable at night but suffer quite a shallow dof (focus).
One last point, I hope the installer used solid copper POE cable and not CCA (Copper coated aluminium).
