Huisin PTZ software settings blank in browsers
Bradmph
Pulling my weight
Joined
Aug 16, 2015
Messages
264
Reaction score
160
Location
Planet Earth
I am getting some strange action from the Huisin PTZ camera I use for license plate reading. I was going to do a firmware update and none of my browsers can get any info from the camera setup. I run the Huisin with some hiks and 7-35 zoom and those all give the settings correctly in browser. System is a dedicated win10 64bit updated and updated BI is latest version of 4. If I go to change settings, some boxes allow it to happen, some don't and will act like they save, but it reverts back to empty view like in the images below.
The camera is working OK in BI, I have zoom, the focus is kinda half ass sometimes, I hoped to update firmware to maybe fix that, but the browsers aren't allowing it. It's making triggers and acting normal, just the browsers are like they are getting no connection to the Huisin cam
Cameraguy
Joined
Feb 15, 2017
Messages
1,486
Reaction score
1,134
You try a different browser?
gordo
Pulling my weight
Joined
Apr 17, 2014
Messages
253
Reaction score
188
Brad, ONVIF device manager from sourceforge has 2 reset options and a firmware update option. It might be worth a try.
Bradmph
Pulling my weight
Joined
Aug 16, 2015
Messages
264
Reaction score
160
Location
Planet Earth
This program is giving me video and settings finally. I am going to fiddle with it and see if I can do the firmware update and check settings
patrickmx
Joined
Jun 23, 2016
Messages
19
Reaction score
1
Location
mexico
Hi every body
Thanks for this software, it's the only one wich allow me to see again the fields of my Huisun miniPTZ.
But I'm still enable to save any settings.
I've tried with diferent browsers, SADP, SmartPSS, from my DVR.
I'd like to reset the Day/Night Switch to AUTO and I can not. Any way to do it ?
eeeeesh
BIT Beta Team
Joined
Jan 5, 2017
Messages
413
Reaction score
683
I can access all the settings using Chrome with the Internet Explorer Tab (IE TAB) Plugin
IE Tab
patrickmx
Joined
Jun 23, 2016
Messages
19
Reaction score
1
Location
mexico
Thanks for your quick answer... But it doesn't solve my problem : I can see the settings but when I change one, I get this message : SAVE FAILED (see screenshot)
And I still have blank fields in Device Information. But this was solved by using Onvif Device Manager v2.2.250.
eeeeesh
BIT Beta Team
Joined
Jan 5, 2017
Messages
413
Reaction score
683
All I can say is that with the ie tab plugin, I can view all the settings and if I change one, it indicates the save was successful. I did notice the available settings on mine (10x) are slightly different than yours - but I am not sure which Huisun cam your actually dealing with. I have been very pleased with this cam since purchase, it is still going strong capturing license plates, and at this point, I am not about to fool around with the settings, updating firmware, etc
Top
