In the Settings -> Web server menu, when I check the box to Enable the HTTPS: server on port: 443 and click OK on the menu, the web server and the https web page (UI3) comes up and runs just fine. If I go back into that menu, I see a green check mark to the right of the Enable HTTPS line and the web server continues to run until whatever time I shut Blue Iris down (eg when I need to restart the PC, etc).
After Blue Iris has been shut down and then restarted, if I go back into the Settings -> Web server menu, I see the box still checked to Enable the HTTPS: server (as it should be), but I have an orange triangle with a "!" to the right of that line and the webserver does not come up.
If I uncheck the box to Enable the HTTPS: server and click OK on the menu, then go back and recheck the box to Enable the HTTPS: server and OK the menu, then once again the website comes up and runs and the green check mark to the right of the Enable HTTPS line is back.
So, for some reason, it seems some process occurs, only when Blue Iris is starting up, that interferes with the web server startup. Since I don't have to restart Blue Iris very often, I have not been terribly overburdened with manually starting the web server, but it would be nice if it would start automatically when Blue Iris starts.
Anybody have an idea as to why the web server is not starting automatically when Blue Iris starts?
