No. Firefox here.Anyone else using firefox and this site getting blocked by both firefox and malwarebytes (trojan horse warning)?
No. Firefox here.
I just did 2 - 2496 and 6 - 2499 Amcrest cameras using DH_IPC-HX5X3X-Rhea_MultiLang_NP_Stream3_V2.800.0000014.0.R.191203.bin with NO problems at all.
Odds are you were asking iseeker but as far as my config, (post #43), nah, changing over to dahua did nothing for my features with BI. (Amcrest IP8M-2493E )Did you gain anything by updating the firmware to Dahua's? I know you get extra features like IVS etc. but if you are using BI are they useful? I am in doubt that updating the firmware to Dahua's brings anything strictly for BI usage.
Is there a way to roll back to Amcrest firmware if I reflashed my Amcrest camera with Dahua?
accepting requests..
Open TFTP Server MultiThreaded Version 1.64 Windows Built 2001
starting TFTP...
alias / is mapped to root\
permitted clients: all
server port range: all
max blksize: 65464
default blksize: 512
default timeout: 60
file read allowed: Yes
file create allowed: Yes
file overwrite allowed: Yes
thread pool size: 1
Listening On: 192.168.254.254:69
Client 192.168.1.108:3109 root\upgrade_info_7db780a713a4.txt, 1 Blocks Served
Client 192.168.1.108:3284 root\romfs-x.squashfs.img, 973 Blocks Served
Client 192.168.1.108:1500 root\kernel.img, 1178 Blocks Served
Client 192.168.1.108:3657 root\user-x.squashfs.img, 13308 Blocks Served
Client 192.168.1.108:1345 root\web-x.squashfs.img, 3953 Blocks Served
Client 192.168.1.108:1411 root\partition-x.cramfs.img, 5 Blocks Served
Client 192.168.1.108:2312 root\custom-x.squashfs.img, 853 Blocks Served
Client 192.168.1.108:3187 root\pd-x.squashfs.img, 47 Blocks Served
Client 192.168.1.108:1135 root\.FLASHING_DONE_STOP_TFTP_NOW, 1 Blocks Served
Client 192.168.1.108:3496 root\success.txt, File not found or No Access
Client 192.168.1.108:3106 root\upgrade_info_7db780a713a4.txt, 1 Blocks Served
Client 192.168.1.108:3281 root\romfs-x.squashfs.img, 973 Blocks Served
Client 192.168.1.108:1475 root\kernel.img, 1178 Blocks Served
Client 192.168.1.108:3567 root\user-x.squashfs.img, 13308 Blocks Served
	Ncat: Version 7.40 ( https://nmap.org/ncat )
Ncat: Listening on 192.168.254.254:5002
tition file version 2
rootfstype squashfs root /dev/mtdblock8
partition file version 2
fail to load bootargsParametersV22.txt
fail to load bootargsParametersV21.txt
Using ambarella mac device
TFTP from server 192.168.254.254; our IP address is 192.168.1.108; sending through gateway 192.168.1.1Download Filename '.FLASHING_DONE_STOP_TFTP_NOW'.Download to address: 0x2000000
Downloading: #
done
fail to load bootargsParameters.txt
fail to load bootargsParameters.txt file
get bootargs info failed
cmdLine console=ttyS0,115200 mem=150M root=/dev/mtdblock8 rootfstype=squashfs init=/linuxrc
arella mac device
TFTP from server 192.168.254.254; our IP address is 192.168.1.108; sending through gateway 192.168.1.1Download Filename 'romfs-x.squashfs.img'.Download to address: 0x2000000
Downloading: *
done
Bytes transferred = 1427704 (15c8f8 hex)
do not find BOOT_IMG_NAME!
Erasing update flag partition.
## Checking Image at 02000000 ...
   Legacy image found
   Image Name:   romfs
   Created:      2019-11-05   9:00:05 UTC
   Image Type:   ARM Linux Kernel Image (uncompressed)
   Data Size:    1427640 Bytes = 1.4 MiB
   Load Address: 01200000
   Entry Point:  01600000
   Verifying Checksum ... OK
Programing start at: 0x01200000
write : 100%
done
TFTP from server 192.168.254.254; our IP address is 192.168.1.108; sending through gateway 192.168.1.1Download Filename 'kernel.img'.Download to address: 0x2000000
Downloading: *
done
Bytes transferred = 1728248 (1a5ef8 hex)
   Legacy image found
   Image Name:   kernel
   Created:      2019-11-05   9:00:03 UTC
   Image Type:   ARM Linux Firmware (uncompressed)
   Data Size:    1728184 Bytes = 1.6 MiB
   Load Address: 00c80000
   Entry Point:  01200000
Programing start at: 0x00c80000
write : 100%
done
TFTP from server 192.168.254.254; our IP address is 192.168.1.108; sending through gateway 192.168.1.1Download Filename 'user-x.squashfs.img'.Download to address: 0x2000000
Downloading: *
done
Bytes transferred = 19536120 (12a18f8 hex)
   Legacy image found
   Image Name:   user
   Created:      2019-11-05   9:00:31 UTC
   Image Type:   ARM Linux Standalone Program (uncompressed)
   Data Size:    19536056 Bytes = 18.6 MiB
   Load Address: 01e00000
   Entry Point:  03a80000
Programing start at: 0x01e00000
write : 100%
done
TFTP from server 192.168.254.254; our IP address is 192.168.1.108; sending through gateway 192.168.1.1Download Filename 'web-x.squashfs.img'.Download to address: 0x2000000
Downloading: *
done
Bytes transferred = 5802232 (5888f8 hex)
   Legacy image found
   Image Name:   web
   Created:      2019-11-05   9:00:09 UTC
   Data Size:    5802168 Bytes = 5.5 MiB
   Load Address: 01600000
   Entry Point:  01e00000
Programing start at: 0x01600000
write : 100%
done
TFTP from server 192.168.254.254; our IP address is 192.168.1.108; sending through gateway 192.168.1.1Download Filename 'partition-x.cramfs.img'.Download to address: 0x2000000
Downloading: *
done
Bytes transferred = 6392 (18f8 hex)
   Legacy image found
   Image Name:   partition
   Created:      2019-11-05   9:00:02 UTC
   Data Size:    6328 Bytes = 6.2 KiB
   Load Address: 00500000
   Entry Point:  00600000
Programing start at: 0x00500000
write : 100%
done
TFTP from server 192.168.254.254; our IP address is 192.168.1.108; sending through gateway 192.168.1.1Download Filename 'custom-x.squashfs.img'.Download to address: 0x2000000
Downloading: *
done
Bytes transferred = 1251576 (1318f8 hex)
   Legacy image found
   Image Name:   custom
   Created:      2019-11-05   9:00:47 UTC
   Data Size:    1251512 Bytes = 1.2 MiB
   Load Address: 00600000
   Entry Point:  00940000
Programing start at: 0x00600000
write : 100%
done
TFTP from server 192.168.254.254; our IP address is 192.168.1.108; sending through gateway 192.168.1.1Download Filename 'pd-x.squashfs.img'.Download to address: 0x2000000
Downloading: *
done
Bytes transferred = 67832 (108f8 hex)
   Legacy image found
   Image Name:   pd
   Created:      2019-11-05   9:00:45 UTC
   Data Size:    67768 Bytes = 66.2 KiB
   Load Address: 00940000
   Entry Point:  00c80000
Programing start at: 0x00940000
write : 100%
done
par
	The IR light will glow red.Attempt to buy this IP8M-T2499EW (4mm version)
1. Hope anyone can kindly help to let me know if this camera at night time will NOT show any glow (absolutely no light).
2. How far (feet or meter) the camera can see in a clear picture if I buy the 4mm version ?
Thanks a lot.
It's not bright but it absolutely can be seen. Glow is a good description. I have 6 of these (all 2.8mm) and tested turning off the IR light in my darkest area. It does not see well at all with no light but does a much better job with the built-in IR turned on, which is how I use them. These are great daytime cameras and OK for night.
I have 2 Dahua IPC-T5442TM-AS cameras, 1 - 2.8mm and 1 - 4mm. They are both great daytime and amazing nighttime cameras.
Dont be paranoid about the ir glow. Someone seeing the camera is not a bad thing. They can see the camera during the day with no ir glow. There are two different versions of the same camera, one with IR light one with LED white light. All cameras with IR light have visible 850nm IR light because it has a stronger effect. The 5442 is a dahua camera, amcrest does not rebrand this model.Thanks Schnoidz. as learning from you all here, can you share your experiences ? This will help me to choose either one for my driveway which has no light.
1. how far will the images for the IP8M-T2499EW (with turn-off the IR) can be reasonabely-clear seen ?
2. your IPC-T5442TM-AS 4mm starlight+ cameras doesn't have glow at night (in b/w), right ? What is your experiences ? [I read a review saying this one doesn't have the IR filter cut. but another article saying IR LED's are under the black plastic cover. people wont see them unless you're looking at them at night.]
3. does IPC-T5442TM-AS have the firmware converting from Amcrest to Duhua for the additional IVS type of features ?
Many thanks to you and all.
Thanks for the heads up! My friend just ordered one and should be getting his within a week. Did you just basically load the dahua firmware and it took it?Just flashed an Amcrest NVR NV4108E-HS with Dahua firmware. Used the firmware from this model. Dahua Wiki
Looks like I gained some Ai functionality...still need to play around with it.
Pretty much, installed with no issues. Can access the video now on chrome with no plugins. Amcrest firmware needed IE or some awful chrome extension.Thanks for the heads up! My friend just ordered one and should be getting his within a week. Did you just basically load the dahua firmware and it took it?
