You may have to reset your Dahua camera and start all over. Then see if the Dahua config program will see it.
Is the camera on the LAN, or on an NVR POE port?I am having the same issues trying to get my Dahau cam working with the Hikvision NVR.
Either way - the first thing you need to ensure is that the camera is on the same IP address range as the NVR (either it's LAN interface, or it's POE interface) is using.
What is the IP address of either the NVR LAN interface, or the NVR POE channel you want to plug the camera in to?
What is the IP address of the camera?
Here is an example of a Dahua camera, connected to the LAN, working on a Hikvision NVR -
It will be OK when the IP addresses are set correctly.I tried your settings and still did not work.
Presumably the NVR POE port you want to connect the camera to has something like 192.168.254.x configured.
You would need to change the camera IP address to match, then plug it in to the NVR POE port.
Nobody tried to help me but I am not as somebody so I came back to tell you where was the problem.
I have changed the password in all cameras from factory to my own.
But during my configuring the nvr was saying wrong password so I tried the factory password (which has been changed) and the cameras switch in online mode!
Right now I have no picture, so I am finding why :-(
Hello. I have a similar issue. Could you help me?
I tied to connect from DS-7104HGHI-F1 (V3.4.1 build 151221) to Dahua NVR5232-4KS2 (V3.216.0000003.0, Build Date: 2018-12-11) via RTSP. But I allways see the error "authorization is possible after a timeout".
Hikvision DVR works good with Turbo HD Hikvision Cam. But I need to connect this two registrators.
Login/Password - correct.
VLC player - correct plying video as well.
I am thinking I need downgrate Dahua NVR5232-4KS2. Maybe somebody has a fireware? Please.
I'll be very grateful
Hi
I try configure in my bussines to add camera Dahua to IVMS-4200 from HikVision. But i can not. I add device by ONVIF on port 80 but still can not see live view.... Please help me.
