Not that ive seen....You can mount a junction box or if you have siding, you can use a siding mount..there should be enough clearance with a siding mount to mount the connection behind the mount (between the mount and siding) or if you use a turret, you should have just enough room to stuff the cable but using a siding mount will give you room to breath.. https://www.google.com/search?q=sid...PwFKAFqFQoTCLvI_JDCk8cCFcU3PgodgrYHRA&dpr=0.9Do any of the Hik's or Dahua cameras (outdoor) have the ethernet port on the actual camera instead of a pigtail?
I really do not feel like drilling a 1" hole in my exterior wall if I can get away with 5/16" (and then crimp an RJ45 on the cable.
Thanks - I do not have siding... Instead I'd be mounting it on wood above my front door.
I plan to go with a turret at this time.
It's really surprising that these vendors don't have an easy way to use smaller holes - like even if using a pigtail, maybe it connects to the camera using a micro-USB type connector or something... While I realize that might not be the right platform, surely a connector that would allow a SMALL hole to be used rather than a 1" one.
A 5/16" hole is literally 1/10th the area of a 1" hole. Easier to plug up, insulate, etc...
Hi, I have just received a DS-2CD2142FWD-IWS 4MP WDR Camera from AliExpress. Now I need to get a POE injector. In the manual for the camera and on the camera itself, it is written it runs on 12V current. I tried to order a 12V poe injector from AliExpress, but the seller claims I need a 48V injector. Anyone who know which is right / can post a link to a suitable poe injector?
I use a 2.8 to cover my driveway and the front street as I live in a cul-de-sac. Every other camera is 4mm for me.
Bad news ! Hik are removing crossing line in the new 4mp ?
Razer and MrFixit, do you have any shots of your 4mm and 2.8mm you could send our way? I might consider doing a 2.8mm at the front door as both of you suggest and then 4mm or 6mm for the other areas.
Just wrap the connection with coax seal and it will be fine..With respect to the pigtail being stuffed in the camera...
I forgot to mention that I'm mounting it above a door - where an overhead roof (for the front porch) would extend 7-8 feet out in front, and 3-4 feet to the nearest side.
It would not be hit by direct liquid moisture. Water in the form of humidity - sure, but it is well protected from rain or melting snow.
Two cars wide.How wide is your driveway? My driveway is 2 cars wide and 4mm lens covers that perfect with a little leftover![]()
