Bjthomas09
Did you end up figuring this out. I use action tiles myself and then only stream type you can use for viewing of media stream is MJPEG in action tiles. You can either set the encoding in the camera as mentioned above or if using VLC you can get VLC to encode the RTSP stream as MJPEG, the best/easiest option is to use blue iris as it makes it very easy to re encode the RTSP stream as MJPEG stream which can be easily added to action tiles..How odd! Mine doesn't do that, i wonder if it is to do with opening ports on my security gateway. I didn't think it would be as it was internal, but maybe that is the reason it isn't working.
I'll make sure to keep you posted, thank you for your help so far.
