Hikvision Product Comparison
olli
Joined
Jan 5, 2015
Messages
112
Reaction score
54
Confused with Hikvision model numbers? And features included in specific cameras? Please have a look at this easy-to-read spreadsheet. It'll also give you the prices of cameras from three reputable sellers, it is safe to order from them. In this thread, you can also ask about differences of the models.
>> Hikvision Product Comparison - Google Sheets
(both cameras and NVRs now compared!)
Important thing to note:
If you purchase a Hikvision camera / NVR from Aliexpress, you should not upgrade the firmware. If you upgrade it, the user interface will be in Chinese only. Despite there are some solutions to this issue, it's better not to upgrade the firmware if you are unsure.
S474N
Joined
Feb 18, 2015
Messages
151
Reaction score
11
I think, that the best model (value for money) is DS-2CD2132F-IS.
Why you don't have in table also "Alarm IN/OUT Interface"?
Tony G
Joined
Mar 12, 2015
Messages
14
Reaction score
Thanks, that's a useful spreadsheet.
I changed the camera type for the 2332 to 'Turret' from 'mini-dome'. I hope that's ok.
olli
Joined
Jan 5, 2015
Messages
112
Reaction score
54
Alarm I/O and Audio I/O , I have now added. Thanks a lot for the suggestion! :)
And Tony G, you're welcome. No problem, a very good change, thanks!
johngalt
Joined
Dec 16, 2014
Messages
149
Reaction score
19
Thanks, just ordered first cam from CCTV China. Wouldn't of risked the overseas transaction without the recommendations/trials/tribulations of the ipcamtalkers.
S474N
Joined
Feb 18, 2015
Messages
151
Reaction score
11
It would be OK, but you cannot upgrade firmware.
olli
Joined
Jan 5, 2015
Messages
112
Reaction score
54
I have now added axis information to the spreadsheet. If you can, please help by checking it. Also some video explaining the "axis" for beginners like me would be preferred (to be used in the help section). Thank you.
fenderman
Staff member
Joined
Mar 9, 2014
Messages
36,907
Reaction score
21,295
Great. Both 2532 cameras are 3 axis...
rawbar
Joined
Mar 31, 2015
Messages
43
Reaction score
5
Would it be accurate to assume that turret, bullet and Dome are outdoor cameras while Cube is indoor?
olli
Joined
Jan 5, 2015
Messages
112
Reaction score
54
Yes, though, as far as I know, all the models can be used indoors. But the cube cameras indoors only.
about the NVR part : sorry for taking so long time with it. Hikvision NVRs are very confusing, and it takes to time compare between models. Hopefully you'll understand and any help is appreciated. Thanks.
olli
Joined
Jan 5, 2015
Messages
112
Reaction score
54
Good idea, but I have thought to list only the most popular models and price of which is below 200$ (ok for consumers). But, I'm open for ideas, one expensive model wouldn't be bad at all. If you know one, please tell me or add to the list directly. :)
S474N
Joined
Feb 18, 2015
Messages
151
Reaction score
11
Yes, it is expensive, but PTZ with 20-30x zoom is best :)
olli
Joined
Jan 5, 2015
Messages
112
Reaction score
54
Okay... i'll have to add it to the list maybe:)
Question to everybody:
as CSST seems not to be reliable now, does anyone know a good supplier for Hikvision NVRs without PoE? cctv camera china only supplies them with PoE.
jacky
Joined
May 11, 2015
Messages
2
Reaction score
Location
shenzhen china
CSST means: Chia security & Surveillance Technology? one biggest of CCTV Equipment supplier in shenzhen?
ivarsand
Joined
Mar 24, 2015
Messages
8
Reaction score
1
A Hikvision representative pointed me to the new inexpensive speed dome cameras. Zoom is only 2x but pan 350 degrees and tilt 90 degrees with presets.
DS-2DE2102 1.3 MB
DS-2DE2202-DE3/W 2MB
http://overseas.hikvision.com/en/Products_accessries_498_i5554.html
http://www.aliexpress.com/wholesale?catId=0&initiative_id=AS_20150522043727&SearchText=ds-2de2202-DE3/W
And DS-2DE2202I-DE3/W 2MB for indoor with IR. This is available in Chinese version now but is soon to appear in international version.
http://www.aliexpress.com/wholesale?catId=0&initiative_id=SB_20150522051622&SearchText=DS-2DE2202I-DE3/W
Make note that it is a Chinese 5.3.0 version, but menu similarities and the Onvif software makes it very usable for non Chinese buyers.
Top
