Hey i updated my DS-7608NI E2/8p to v3.480 and it fixed the email issue
Interesting.Hey i updated my DS-7608NI E2/8p to v3.480 and it fixed the email issue
During playback i am not seeing any motion markings.Let me add also that all my cams are on the latest firmware v5.40 . And on cam settings under email they all have the option to select TLS and Enable STARTTLS which i both selected on port 587. But after the latest nvr update i notice these options are not there on NVR or not yet addedInteresting.
If you have time, and have the cameras and NVR set up with motion detection and continuous recording, could you see if the web GUI Playback timeline shows motion markings along the continuous line?
We seem to have variable experience with that on this firmware.
I used Eng FW since i have 7608 international english version bought from Aliexpressi would like to upgrade mine to try it but not sure http://www.hikvisioneurope.com/port...E4/V3.4.80 build160718 English+Multi-lingual/
there now have NVR_K41_BL_EN_STD_V3.4.80_160718.zip and NVR_K41_BL_ML_STD_V3.4.80_160718.zip but which one would you use the nvr sn has AARR - WCVU words in it so it's not a China one?
Check out this new feature in Playback : https://www.ipcamtalk.com/showthrea...-80_160718-zip?p=117623&viewfull=1#post117623
@von101 - is this what you were referring to in your post above?
Yes absolutelyCheck out this new feature in Playback : https://www.ipcamtalk.com/showthrea...-80_160718-zip?p=117623&viewfull=1#post117623
It seems that we have the same NVR model.All i did was to just login to my NVR and upgraded it from hikvision GUI using the browse function. Of course i downloaded it from Hik Euro before , extracted and save to my PC desktop. I think you should not have any concerns about correct FW. It validates firstly.i think he does would you use eng or overseas just worried about stuffing it up
Check out the seemingly greyed-out icon at the bottom left of the Playback web GUI screen.Yes absolutely
You really are a complete idiot saying stuff like this. You've posted 4 times in different threads asking the same stupid question and can't be bothered to do any research. This is spamming.I bet you're one of those that voted for Brexit.
Brexit was a great move....why do you refer to voting for it as a negative?...makes no sense to me....I bet you're one of those that voted for Brexit.
Not for Scotland - we didn't vote for it, a definite No vote, as opposed to the almost balanced result overall.Brexit was a great move....why do you refer to voting for it as a negative?...makes no sense to me....
