HIKVISION mtd Brick Recovery Guide
S474N
Joined
Feb 18, 2015
Messages
151
Reaction score
11
Hi, which is the newest firmware for chinese DS-2CD2132F-IS?
S474N
Joined
Feb 18, 2015
Messages
151
Reaction score
11
I need English language, please.
S474N
Joined
Feb 18, 2015
Messages
151
Reaction score
11
Please look:
- I have Chinese version of camera (CCCH in serial number)
- now I have hacked cameras with English/Czech language with firmware V5.2.3 build 141024
Is possible to upgrade do newest version of firmware? Which is the newest "hackable"? And how can I do it :)
Thanks for reply!
S474N
Joined
Feb 18, 2015
Messages
151
Reaction score
11
OK, thank you. But which firmware of 5.4.5 will I use?
alastairstevenson
Staff member
Joined
Oct 28, 2014
Messages
15,980
Reaction score
6,802
Location
Scotland
If the camera is truly a China market camera, then if you use any of the EN/ML firmware the camera will stop working.
Check the link 3 posts back, also at the bottom of this post, for the 'enhanced mtd hack'.
To make the camera upgradeable to the EN/ML firmware you would need to do the 'enhanced mtd hack' from here : Hikvision DS-2CD2x32-I (R0) brick-fix tool / full upgrade method / fixup roundup.
S474N
Joined
Feb 18, 2015
Messages
151
Reaction score
11
OK, will try it, but is there some "step-by-step" manual?
keptphree
Joined
Dec 2, 2017
Messages
4
Reaction score
1
Is there an updated link to the 5.2.5 CH version so I can load it back on my camera. It is fully bricked...
This is all I see now.. the TFTP works...
HIKvision MTD Brick Recovery
This is to recover you bricked camera, after trying to do the MTD5 & MTD6 and failing.
You will need the 5.2.5 firmware get it here.
Dropbox - Error
Also Hikvision's tftp updater and an ftp program (I use Cute ftp) & of course Telnet.
You will also need your original mtd5 & mtd6 files.
Set your PC IP to 192.0.0.128
1st run the tftp updater (with the 5.2.5 file in the tftp folder) let it update and finish, but don't close it!
now run Telnet and logon to the camera with
192.0.0.64
User= root
password= 12345
Now type
- ftpd &.
(Don't close Telnet)
This will start the ftp service on the camera.
Now using your FTP Program login in to the Camera.
192.0.0.64
User= root
password= 12345
Now copy over your mtd5 & mtd6 files with ftp to /tmp/ (name your files mtd5_temp & mtd6_temp).
Now back to Telnet.
cd /tmp/
cat mtd5_temp > /dev/mtdblock5
cat mtd6_temp > /dev/mtdblock6
Now close tftp updater & FTP Program.
Now back to Telnet.
reboot.
All done your camera will now restart and if you followed this correctly, you won't have a brick any more.
S474N
Joined
Feb 18, 2015
Messages
151
Reaction score
11
Today succesfully upgraded one CH from 5.2.3 to 5.4.5 original ENG firmware (5.2.3 -> 5.3.0 -> 5.4.0 -> 5.4.5).
Have question - 5.4.5 is newest firmware, which can I use with modified mtdblocks? Or is it is the last firmware from Hik and they stop support this cams?
alastairstevenson
Staff member
Joined
Oct 28, 2014
Messages
15,980
Reaction score
6,802
Location
Scotland
It's looking like this is the case - unless they create a newer version to break cameras that have had the 'enhanced mtd hack'.
Was this after doing the 'enhanced mtd hack'?
The 5.4.5 firmware works OK after the 'enhanced mtd hack'.
S474N
Joined
Feb 18, 2015
Messages
151
Reaction score
11
Yes, of course :) EMH and then upgraded. Now I'm doing/upgrading 5'th cam.
S474N
Joined
Feb 18, 2015
Messages
151
Reaction score
11
Now I have problem with one cam. mtdblock1 is absolutely empty. Can I upgrade it to 5.3.0?
Top
