Hello Sir,
I need your technical assistance regarding a Hikvision IP Camera with a firmware/language issue. Below are the complete details:
Camera Model: DS-2CD26E6CMDV3-IZS
Serial Number: DS-2CD26E6CMDV3-IZS20210201AACHF38451899
Current Firmware: V5.6.6 build 220307
Encoding Version: V7.3 build 220307
Firmware Version Property: B-R-G1-0
Web Version: V4.0.1
The camera itself is working and I can access its web interface normally. I have also installed the required Hikvision web component.
I tried upgrading the camera using different digicap.dav firmware files, but the firmware upgrade does not complete successfully. The upgrade either fails or remains stuck, so I do not want to continue testing random firmware because there is a risk of bricking the camera.
I can provide PCB photos, memory-chip markings, current firmware files, configuration information, screenshots, or a flash dump if required.
Thank you.
Web Version: V4.0.1
Problem
The camera is currently operating with a Chinese firmware/interface, and I need to change it to English/International firmware.The camera itself is working and I can access its web interface normally. I have also installed the required Hikvision web component.
Assistance Required
Could you please help me determine:- The exact compatible English/International firmware for this specific camera and hardware revision.
- Whether this Chinese-region camera can safely be converted to an English/International region.
- Whether firmware from another DS-2CD26E6CMDV3-IZS with the same hardware revision can be used.
- If normal web/SADP/TFTP firmware upgrade is not possible, whether the camera can be recovered/programmed directly through its SPI NOR, NAND, or eMMC flash memory using a hardware programmer.
- If direct programming is possible, which programmer and procedure should be used.
- Whether a full flash dump from an identical working camera can be written to this camera.
- Which partitions contain the bootloader, firmware, region/language information, serial number, MAC address, and calibration data, so that device-specific information is not accidentally overwritten.
- If you have the correct digicap.dav, recovery firmware, full flash dump, or service/recovery procedure for this exact model, please share it with me.
Thank you.
