Paul Arthur
- Apr 30, 2016
- 220
- 16
I have the same bloody problem with my Hikvision cameras i got a 2x4tb purple WD40PURZ
i have
NVR : DS-7616NI-I2 / 16P running V4.1.50 build 180227
x 2 x DS-2CD2385FWD-I (8mp) running V5.5.51 build 180408
x 2 x DS-2CD2T85FWD-I8 running V5.5.51 build 180408
i'm getting skips also i played around a lot today and found that I Frame Interval from 50 to 80 has fixed some up
this is really annoying and i'm so close on removing hikvision from my life (selling the crap and going dahua) hikvision need to fix this annoying bug in there nvr systems i belive it could be the NVR doing it of WD hard drive i'm going to remove both later and replace with a 8tb wd purple where the cache size might be the problem
WD121PURZ 12TB SATA 6Gb s 7200 rpm 256MB not sure if supported
WD100PURZ 10TB SATA 6Gb s 5400 rpm 256MB not sure if supported
WD101PURZ 10TB SATA 6Gb s 7200 rpm 256MB not sure if supported
WD80PURZ 8TB SATA 6Gb s 5400 rpm 128MB
WD81PURZ 8TB SATA 6Gb s 5400 rpm 256MB (this model is the best)
WD60PURZ 6TB SATA 6Gb s 5400 rpm 64MB
WD40PURZ 4TB SATA 6Gb s 5400 rpm 64MB
i have
