trempa92
Getting comfortable
trempa92, thank you very much for your help !
(or Hvala vam like you say)
After the factory reset (called "RESTORE ALL") on both units, I did the following.
Doorbell (IP : x.y.z.110):
- set IP address of my LAN (or DHCP)
- Intercom/session settings, set IP address of the indoor station under "Main station IP" x.y.z.111
Indoor Station (IP : x.y.z.111):
- Local Network Configuration, set network address (or DHCP)
- Group Network Settings, Main Station IP address to be that of the indoor station x.y.z.111
- Group Network Settings, (Main) Door Station IP address to be that of the Doorbell x.y.z.110
[*]Registration password
That was all... and the simple doorbell function works !
Now I shall try to make SIP work...
N.B. With the HikVision SADP application you can set the network of the units to DHCP.
Main station needs to be 0.0.0.0 if its not used. Main station is device that you do not have in this scenario.
