Hikvision DS-7616NI-SE/P Firmware Update
If you have the 'Virtual Host' facility - and you indicated that you do - you shouldn't need to use all this fiddly stuff and get frustrated by it ...
And to your last question - yes, the PoE cameras are fully accessible, including the ability to mess with their internal over SSH, for example:
192.168.1.99 is the PC I'm using for access. 192.168.1.201 is the QNAP NAS box running Surveillance Station, recording the camera's video stream and motion detection alerts.
login as: admin
[email protected]'s password:
BusyBox v1.19.3 (2014-07-11 11:25:54 CST) built-in shell (ash)
Enter 'help' for a list of built-in commands.
# ifconfig
eth0 Link encap:Ethernet HWaddr C0:56:E3:83:A5:A3
inet addr:192.168.254.11 Bcast:192.168.254.255 Mask:255.255.255.0
inet6 addr: fe80::c256:e3ff:fe83:a5a3/64 Scope:Link
UP BROADCAST RUNNING MULTICAST MTU:1500 Metric:1
RX packets:387711973 errors:0 dropped:24 overruns:0 frame:0
TX packets:419853955 errors:0 dropped:0 overruns:0 carrier:0
collisions:0 txqueuelen:1000
RX bytes:2520240141 (2.3 GiB) TX bytes:2416335378 (2.2 GiB)
Interrupt:27
lo Link encap:Local Loopback
inet addr:127.0.0.1 Mask:255.0.0.0
inet6 addr: ::1/128 Scope:Host
UP LOOPBACK RUNNING MTU:16436 Metric:1
RX packets:390 errors:0 dropped:0 overruns:0 frame:0
TX packets:390 errors:0 dropped:0 overruns:0 carrier:0
collisions:0 txqueuelen:0
RX bytes:29640 (28.9 KiB) TX bytes:29640 (28.9 KiB)
# netstat -a
Active Internet connections (servers and established)
Proto Recv-Q Send-Q Local Address Foreign Address State
tcp 0 0 0.0.0.0:9010 0.0.0.0:* LISTEN
tcp 0 0 0.0.0.0:22 0.0.0.0:* LISTEN
tcp 0 0 0.0.0.0:telnet 0.0.0.0:* LISTEN
tcp 0 0 0.0.0.0:7001 0.0.0.0:* LISTEN
tcp 0 0 0.0.0.0:9020 0.0.0.0:* LISTEN
tcp 0 52 192.168.254.11:22 192.168.1.99:9058 ESTABLISHED
tcp 0 0 :::8000 :::* LISTEN
tcp 0 0 :::8200 :::* LISTEN
tcp 0 0 :::554 :::* LISTEN
tcp 0 0 :::22 :::* LISTEN
tcp 0 0 :::90 :::* LISTEN
tcp 0 0 :::443 :::* LISTEN
tcp 0 0 ::ffff:192.168.254.11:554 ::ffff:192.168.254.1:35529 ESTABLISHED
tcp 0 0 ::ffff:192.168.254.11:554 ::ffff:192.168.1.201:47178 ESTABLISHED
tcp 0 0 ::ffff:192.168.254.11:90 ::ffff:192.168.1.201:60058 ESTABLISHED
tcp 0 0 ::ffff:192.168.254.11:554 ::ffff:192.168.254.1:57013 ESTABLISHED
tcp 0 0 ::ffff:192.168.254.11:8000 ::ffff:192.168.254.1:39253 ESTABLISHED
udp 0 0 0.0.0.0:47872 0.0.0.0:*
udp 0 0 0.0.0.0:3702 0.0.0.0:*
udp 0 0 0.0.0.0:5353 0.0.0.0:*
udp 0 0 :::3702 :::*
udp 0 0 :::47771 :::*
udp 0 0 :::5353 :::*
Active UNIX domain sockets (servers and established)
Proto RefCnt Flags Type State I-Node Path
unix 2 [ ] DGRAM 45 @/org/kernel/udev/udevd
unix 2 [ ACC ] STREAM LISTENING 1625 /var/g_daemon_service
unix 2 [ ACC ] STREAM LISTENING 1629 /var/systemCmd.socket
unix 3 [ ] STREAM CONNECTED 1631 /var/net_worker_process
unix 3 [ ] STREAM CONNECTED 1686 /var/davinci_work_process
unix 2 [ ACC ] STREAM LISTENING 2835 /tmp/aaa
unix 2 [ ] DGRAM 2917 /var/run/wpa_supplicant/eth0
unix 3 [ ] STREAM CONNECTED 1632 /var/g_daemon_service
unix 3 [ ] STREAM CONNECTED 1626 /var/g_daemon_service
As I said I cannot telnet to the cameras connected to the NVR.
The ifconfig and netstat you send me is from your camera. Can you please send me the same from your NVR?
This is my netstat -r from within my NVR. If I interpret it correctly the poe interface 192.168.254.0 does not have a gateway. Am I correct?
Can you please remind me how to add the route manually from the command line?
# netstat -r
Kernel IP routing table
Destination Gateway Genmask Flags MSS Window irtt Iface
192.168.1.0 * 255.255.255.0 U 0 0 0 eth0
192.168.254.0 * 255.255.255.0 U 0 0 0 poe0
default 192.168.1.1 0.0.0.0 UG 0 0 0 eth0
NVR routing table (snap!) and interface config as requested:
dvrdvs login: root
Password:
BusyBox v1.16.1 (2014-05-19 09:41:10 CST) built-in shell (ash)
can not change to guest!
[root@dvrdvs /] # route -e
default 192.168.1.1 0.0.0.0 UG 0 0 0 eth1
192.168.1.0 * 255.255.255.0 U 0 0 0 eth1
192.168.254.0 * 255.255.255.0 U 0 0 0 eth0
224.0.0.0 * 240.0.0.0 U 0 0 0 eth1
[root@dvrdvs /] # ifconfig
eth0 Link encap:Ethernet HWaddr 8C:E7:48:6F:81:28
inet addr:192.168.254.1 Bcast:192.168.254.255 Mask:255.255.255.0
inet6 addr: fe80::8ee7:48ff:fe6f:8128/64 Scope:Link
RX packets:1476500466 errors:0 dropped:0 overruns:0 frame:0
TX packets:252705634 errors:0 dropped:0 overruns:0 carrier:0
RX bytes:3427437587 (3.1 GiB) TX bytes:175862076 (167.7 MiB)
Interrupt:59
eth1 Link encap:Ethernet HWaddr 8C:E7:48:6F:81:27
inet addr:192.168.1.210 Bcast:192.168.1.255 Mask:255.255.255.0
inet6 addr: fe80::8ee7:48ff:fe6f:8127/64 Scope:Link
RX packets:947332339 errors:0 dropped:682 overruns:0 frame:0
TX packets:591354207 errors:0 dropped:0 overruns:0 carrier:0
RX bytes:2348566756 (2.1 GiB) TX bytes:3015876849 (2.8 GiB)
Interrupt:59 Base address:0x4000
RX packets:1766 errors:0 dropped:0 overruns:0 frame:0
TX packets:1766 errors:0 dropped:0 overruns:0 carrier:0
RX bytes:301040 (293.9 KiB) TX bytes:301040 (293.9 KiB)
[root@dvrdvs /] #
Reactions: aster1x
Now the NVR started forwarding camera traffic through the NVR LAN port to the LAN !!!!!:):)
This is very weird. I will let it work for the tonight and see tomorrow.
Thanks alastair.
